    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    2.2k Posts 482 Posters 852.1k Views 487 Watching
    • CadFatherC Offline
      CadFather
      First let me say Thank you to Fredo6 for the many years of free incredible plugins, support and sheer pleasantness.
      Did a purchase for many of the plugins, however am not able to use them. (I'm all updated, internet etc.)
      Start the plugin
      License pops up
      I validate
      All good and green
      try the plugin
      License pops up
      I validate
      All good and green...
      Just cannot get past this loop.
      If I restart SU, the first first time I call the plugin it works. After that, the loop resumes.
        Hi Max,
        What version of Sketchucation Tools are you running?
          CadFather
          Latest one - got yesterday - i think 4.23
          (long time no see hope all is well ๐Ÿ‘ )
          Edit:
          going to empty the extensions folder and start from scratch again
          if no else has reported this - might be a bug my end, so i'll see if i can find it
            Have you installed SketchUp by selecting its installer's exe file [usually in Downloads] and from the right-click context-menu choosing 'Run as administrator', when prompted choose 'Repair'...
            Sometimes preferences files etc are created with incorrect permissions if the original installation was not perfect...
            So check that C:\Users\YOURNAME\AppData\Local\SCF Licenses Properties > Security has 'Full control' permissions set for everyone listed [Edit]...
            Also in the same ...\Local folder do the same for subfolder \LIBFREDO6_DATA_Dir folder and its contents...
              CadFather
              I have ownership of those folders - but will double check all permissions
              is there a particular reason why these are not in appdata so we can keep them together with the extensions?
              Edit:
              forgot, I installed normally, but not specifically as Admin (though i run my pc that way)
                Running the app as admin is not the same as running the installer as admin - even if your user has admin powers...
                  CadFather
                  well...re-installed SU with admin, check all permissions to all the LOCAL folders you mentioned (i had all)
                  no change
                  then I emptied the whole SCF folder and started all over again - this time it worked!
                  at least TOS, Spline and Curvizard are good so far - others still to check.
                  Thanks guys ๐Ÿ‘
                  • N Offline
                    N_Visualisierung
                    Hallo,
                    leider finde ich nicht den Link wo man die Lizenz kaufen kann.
                    oder was das Fredo6Bundle 2022 fรผr 8 Plugins beinhaltet ?
                    Kann mir bitte einer sagen wo ich verschiedene Plugins kaufen kann?
                    oder mich per Mail kontaktieren ? noack.visualisierung[@]gmx.de
                    GrรผรŸe C.Noack
                      Login and use https://sketchucation.com/purchase.php?plugin=Fredo6Bundle2022
                        BaysideDesigns
                        I am new to Skechup and trying make2017. I am looking for a program to design woodworking projects in and thought I would give it a try. The Fredocorner looks to be a very useful extension. Since i'm trying sketchup out I don't want to pay for an license yet for the Fredocorner and wanted to use the free trial. I downloaded the the extension per the directions two days ago. when I try to use the feature it says it expired back in February.
                        • fredo6F Offline
                          fredo6
                          Could you confirm first if you talk about FredoCorner or RoundCorner.
                            BaysideDesigns
                            It is fredocorner. I had the date wrong also.
                            • fredo6F Offline
                              fredo6
                              Well. It seems you already installed and used FredoCorner around End of January 2021.
                                BaysideDesigns
                                This is the first time I have ever downloaded it and try to use it. So I don't understand!
                                • fredo6F Offline
                                  fredo6
                                  This is strange... but maybe your computer was used with FredoCorner last year. Otherwise< I would not understand why you get this early expiration.
                                  • H Offline
                                    Hugo Marreiros
                                    hi, i had to reinstall sketchup, but i remember to release the license first, but it still shows that i'm using one license, that is not true, how can i correct that?
                                      ramohn
                                      I had the same issue with FredoScale, but I've already bought it, however, I can't use because can't login Extention Store inside Sketchup and consequently I can't validate it
                                      I beg you to help me with my issue or I'll request refund of plugin purchased recently.
                                      ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข
                                        denZ91
                                        Can somebody help me on how to solve this issue please...
                                          denZ91
                                          @fredo6 said:
                                          @unterluggauer said:
                                          Hi Fredo,
                                          I try your instruction. But it doesnt work.
                                          Apparently, you were you able to activate the license for Clothworks. Can you confirm?
                                          Could you try the following.
                                          1. Go to the folder that you showed in your image
                                          2. Delete the file "SCFLicenseSignature...."
                                          3. Try again the procedure
                                          4. You will have to reactivate the license for Clothworks from the purchased license file.
                                          Fredo
                                          I tried this so many times, but that file keeps appearing when i click validate on any fredo plugins and comes out errors. i have bought a package of licenses. Please help
                                            Are you using the right license file to validate? The error message suggests a name mismatch is happening
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 109
                                            • 110
                                            • 7 / 110
