    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Hi Max,
      What version of Sketchucation Tools are you running?
      • CadFatherC
        CadFather
        Latest one - got yesterday - i think 4.23
        (long time no see hope all is well ๐Ÿ‘ )
        Edit:
        going to empty the extensions folder and start from scratch again
        if no else has reported this - might be a bug my end, so i'll see if i can find it
          Have you installed SketchUp by selecting its installer's exe file [usually in Downloads] and from the right-click context-menu choosing 'Run as administrator', when prompted choose 'Repair'...
          Sometimes preferences files etc are created with incorrect permissions if the original installation was not perfect...
          So check that C:\Users\YOURNAME\AppData\Local\SCF Licenses Properties > Security has 'Full control' permissions set for everyone listed [Edit]...
          Also in the same ...\Local folder do the same for subfolder \LIBFREDO6_DATA_Dir folder and its contents...
          • CadFatherC
            CadFather
            I have ownership of those folders - but will double check all permissions
            is there a particular reason why these are not in appdata so we can keep them together with the extensions?
            Edit:
            forgot, I installed normally, but not specifically as Admin (though i run my pc that way)
              Running the app as admin is not the same as running the installer as admin - even if your user has admin powers...
              • CadFatherC
                CadFather
                well...re-installed SU with admin, check all permissions to all the LOCAL folders you mentioned (i had all)
                no change
                then I emptied the whole SCF folder and started all over again - this time it worked!
                at least TOS, Spline and Curvizard are good so far - others still to check.
                Thanks guys ๐Ÿ‘
                • N
                  N_Visualisierung
                  Hallo,
                  leider finde ich nicht den Link wo man die Lizenz kaufen kann.
                  oder was das Fredo6Bundle 2022 fรผr 8 Plugins beinhaltet ?
                  Kann mir bitte einer sagen wo ich verschiedene Plugins kaufen kann?
                  oder mich per Mail kontaktieren ? noack.visualisierung[@]gmx.de
                  GrรผรŸe C.Noack
                    Login and use https://sketchucation.com/purchase.php?plugin=Fredo6Bundle2022
                    • B
                      BaysideDesigns
                      I am new to Skechup and trying make2017. I am looking for a program to design woodworking projects in and thought I would give it a try. The Fredocorner looks to be a very useful extension. Since i'm trying sketchup out I don't want to pay for an license yet for the Fredocorner and wanted to use the free trial. I downloaded the the extension per the directions two days ago. when I try to use the feature it says it expired back in February.
                      • fredo6F
                        Could you confirm first if you talk about FredoCorner or RoundCorner.
                        • B
                          BaysideDesigns
                          It is fredocorner. I had the date wrong also.
                          • fredo6F
                            Well. It seems you already installed and used FredoCorner around End of January 2021.
                            • B
                              BaysideDesigns
                              This is the first time I have ever downloaded it and try to use it. So I don't understand!
                              • fredo6F
                                This is strange... but maybe your computer was used with FredoCorner last year. Otherwise< I would not understand why you get this early expiration.
                                • H
                                  Hugo Marreiros
                                  hi, i had to reinstall sketchup, but i remember to release the license first, but it still shows that i'm using one license, that is not true, how can i correct that?
                                    ramohn
                                    I had the same issue with FredoScale, but I've already bought it, however, I can't use because can't login Extention Store inside Sketchup and consequently I can't validate it
                                    I beg you to help me with my issue or I'll request refund of plugin purchased recently.
                                    ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข
                                      denZ91
                                      Can somebody help me on how to solve this issue please...
                                        denZ91
                                        @fredo6 said:
                                        @unterluggauer said:
                                        Hi Fredo,
                                        I try your instruction. But it doesnt work.
                                        Apparently, you were you able to activate the license for Clothworks. Can you confirm?
                                        Could you try the following.
                                        1. Go to the folder that you showed in your image
                                        2. Delete the file "SCFLicenseSignature...."
                                        3. Try again the procedure
                                        4. You will have to reactivate the license for Clothworks from the purchased license file.
                                        I tried this so many times, but that file keeps appearing when i click validate on any fredo plugins and comes out errors. i have bought a package of licenses. Please help
                                          Are you using the right license file to validate? The error message suggests a name mismatch is happening
                                            Derek Edison
                                            I posted this in the Trimble forum and it was recommended that I post it here so I would get notification of any developments:
                                            Is there or will there be an option for corporate customers requiring many licenses to purchase a corporate key or perhaps blocks of licenses? Managing individual licensing per user account is a nightmare for IT admins. PayPal is also a non-starter at a lot of businesses.
                                            I see that there is another payment processor in the works but I don't see anything specific to bulk licensing which is really our issue. I can work around PayPal if I have to. Any information about future plans is appreciated.
                                            • 115
                                            • 116
                                            • 7 / 116
