    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    2.2k Posts 478 Posters 814.4k Views 483 Watching
      Please ensure that you have installed the newest versions of these extensions, LibFredo [helper] and the SketchUcation toolset [for licensing set up] - v4.2.9
      After the installation restart SketchUp to sync everything...
      Retry the tools...
      If this fails to improve things...
      Note that if SketchUp is not installed by using 'Run as administrator' from the right-click context-menu on the installer's exe file [in Downloads] you can get unpredictable and often weird permission issues - running the installer properly usually fixes these issue with a 'Repair' - there is no need to uninstall and any already installed extensions etc are left unaffected...
      Some of Fredo's support files stored away from the main Plugins folder can become inaccessible with very messed up permissions... these can be deleted and when SketchUp restarts they get remade - this time properly... We have already posted details of this previously...
      • P Offline
        paddyclown
        TIG thank you for your reply.
        I did all of that on my SU2022 install and now have the same awful popup window as I mentioned before.
        I again tried to reinstall the LibFredo package using both approved methods, and, in desperation, by copying the files from the .rbz to the plugin folder, but on all three attempts, on restarting SU, this damn window pops up saying that "LibFredo is incorrectly installed, remove, <OK>"
        I can't think what has recently changed in order for the whole thing to act this way...
        Maybe it's the version of windows ? it's Win11 Pro 22H2, build 22621.819
        • P Offline
          paddyclown
          Oh, & for good mesure, I tried what you suggested on another thread...
          "If the error persists, then try [re]deleting the C:/Users/YOUR_USER_NAME/AppData/Local/LIBFREDO6_DATA_Dir directory - because it might have incorrect permissions from any earlier incorrect installation of SketchUp..."
          & sadly that did not fix the issue.
          • Rich O BrienR Online
            I'm on the same Windows build as you and no issues.
            You're renaming the pluginName.rbz to pluginName.zip and unzipping it and placing the contents into the plugins folder at C:\Users\SomeName\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins ???
            Something is not right with install structure for LibFredo to spit out its dummy.
            As a last resort you could rename your Plugins folder to #plugins to prevent it loading. Then fresh install Sketchucation Tools. Use that to install LibFredo and JPP and validate your license.
            Then see if it works. If it does then you know there's something else at play...
            • P Offline
              paddyclown
              OK, good news folks I fixed the problem:
              I got radical and deleted ALL Fredo6 related folders and files from everywhere, then reinstalled all, starting by LibFredo via the SketchUcation toolbar... despite verious error messages, once I restarted SU22 they reworked.
              Fingers crossed that it holds.
              Anyway, thanks all & hope this helps someone sometime.
                Astrid Findreng
                Hi How do I Purchase License for Curviloft
                astrid_findreng@yahoo.no
                  Install the trial using SketchUcation Tools 4.2.9
                  Sketchucation Tools | SketchUcation
                  (sketchucation.com)
                  Then under the Tools > Fredo Collection > Curivloft > License you can buy a license.
                  Or visit https://sketchucation.com/plugin-list.php and purchase it there.
                  You will still need to install Sketchucation Tools 4.2.9 and LibFredo though.
                  SketchUp Plugins | PluginStore | SketchUcation
                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                  (sketchucation.com)
                    Digdaman
                    license seats exceeded.I bought Fredo6Bundle2022 - A bundle of 8 plugin , and validated RoundCorner license.
                    It worked right after I validate it.
                    But,next time I launch SketchUp, The message"Trial Period Expired: RoundCorner" was displayde and it didn't work.
                    I Re-validated Same license. but, it never worked again.
                    I tried various ideas. uninstall, rebooted system and so on.
                    The problem was not resolved. and all license sheats exceeded,
                    though I try at same computer.
                    Please tell me what to do.
                      Visit https://sketchucation.com/webshop/my-licences.php and release seats
                      • Z Offline
                        Zuman Newcomers
                        I am trying to purchase Round Corner Plugin, while paying by PayPal after giving necessary info it doesn't proceed.
                          mahsa1995
                          I need Help please. im getting ERROR_09
                          I purchased my license a while ago but suddenly it said that its ran out but I have purchased the unlimited one.
                          I downloaded the file to validate it again but it keeps opening with wordpad and sketchup wont read it
                          how can i fix this
                            Update Sketchucation Tools
                            (sketchucation.com)
                            Update LibFredo
                            (sketchucation.com)
                            • E Offline
                              emsargeant
                              I'm getting a validation error on my RoundCorner License. Message: 'request to sketchucation = Error_F09'.
                              When I check my license page on SketchUcation it says 0/3 seats...does that mean 0 available? Doesn't seem to allow 'releasing' seats. How can I resolve? Thx.
                                It looks like you're trying to validate FredoCorner and not RoundCorner from that screenshot.
                                  mahsa1995
                                  can i upgrade from Perpetual license to bundle ( its only been a few days since i got the license)
                                    Digdaman
                                    I need your help.
                                    After validating License, I restart sketchup, can't work.
                                    license seats exceeded, though I validate at same PC.
                                    • K Offline
                                      Krop
                                      Hello,
                                      I have a trouble with all of my fredo6 bundle licenses- system drive on one of my devices broke down and I had to replace it- all licenses that were on that computer are blocked.
                                      Could you please release all my fredo6 licenses to the pool so I can assign them to my devices again?
                                        @Digdaman
                                        Have you installed all of the latest versions of the extensions, and LibFredo, and the SketchUcation toolset [for the licensing] and SketchUp restarted ?
                                          @Krop can't you free up licenses from the MyLicenses page at SketchUcation ?
                                          If not come back and Fredo might need to get involved...
                                            tamergad81
                                            Thank you 👊 👍 👍
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 108
                                            • 109
                                            • 64 / 109
