    Bauhaus Lamp
    19 Posts 9 Posters 4.1k Views 9 Watching
    • aviz770A Offline
      aviz770
      I had so much fun with the last lighting piece, I figured I'd try another (slightly more exciting) one! This is a Bauhaus lamp from sometime in the 1920's I believe, and I really loved the "floating" aspect of the shade!
      Thea as always!
      • pbacotP Offline
        That's great! Did you use a Thea material from the online repository for the shade, or what is your approach for that. I always find shades difficult.
          Usual standard, great stuff, rock onnnnnn. πŸ‘
          • locoL Offline
            loco
            Super work. Well done!
            Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
            • alvisA Offline
              alvis
              Nice πŸ˜„
              • HornOxxH Offline
                HornOxx
                ja, nice! but, after all it is a lamp, also a perfect lighting πŸ‘ πŸ‘ (how did you do that?)
                never trust a skinny cook
                • aviz770A Offline
                  aviz770
                  Thanks pbacot! The shade is actually just a single layer Thea material I set up myself! I put a marble texture in the diffuse slot, and then copied the same texture to the transparency slot with the brightness increased +15. There is a very thin "shell" on the inside of the shade, scaled down very slightly, with an emission material applied to it, and this is what's generating the light. It then blends out of the translucent shade texture very nicely. I hope that makes some amount of sense!
                  • aviz770A Offline
                    aviz770
                    Thanks so much Mike!!
                    • aviz770A Offline
                      aviz770
                      Thank you Loco and Alvis!
                      See my reply to pbacot πŸ˜‰
                      • aviz770A Offline
                        aviz770
                        Some more fun with materials too!
                        • Bryan KB Offline
                          Excellent work but that last picture, wow!
                          • pbacotP Offline
                            Thank you. that's looks like a cool technique. I like your other materials a lot too!
                            • aviz770A Offline
                              aviz770
                              A beautiful pair of Wassily Chairs to accompany the lamp...
                              • aviz770A Offline
                                aviz770
                                  A bit too washed out if I'm honest mate, some more contrast would lift it a lot.
                                    Very nice
                                    • aviz770A Offline
                                      aviz770
                                      You're right! I had the burn set way too high and it was washing out all the white tones. Hopefully this one looks a bit better!
                                      • aviz770A Offline
                                        aviz770
                                        • ntxdaveN Offline
                                          ntxdave
                                          Photos should not be allowed! It is supposed to be renders!! LOL
                                          Very nice aviz770 πŸ‘ πŸ‘ πŸ˜‰ πŸ˜„
                                          Press F1...thank me later
