    Drag and drop?
    5 Posts 3 Posters 1.6k Views 3 Watching
      Jorgensen
      I use Connecter from Design Connected to browse my library, and I'm quite sure that I normally could drag and drop assets directly into Sketchup, but now it seems not to be possible any more - or I might be wrong - it was never possible?
      Has any of you any experience using drag and drop?
      I've updated to SU 2020, and I think it might worked in SU 2019....
      Thanks πŸ˜„
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        On a PC you can drag-n-drop things [like images] from another app, e.g. directly into a SketchUp window provided that the apps share the same security clearances.
        If you have inadvertently given an app like SketchUp elevated permissions [perhaps to overcome an incorrect installation?] that it might no longer allow dropped items from/into apps with a different permission level.
        Typically these would include Windows-Explorer, but it could extend to many other apps.
        Any clue there ?
          Jorgensen
          Thanks TIG
          That was the issue - I started Connecter as administrator, and now it works πŸ˜„
          Jorgensen
          • GD3DesignG Offline
            GD3Design
            Connector is a 3DS Max plugin. I believe it is now also compatible with Blender & Cinema4D, but not Sketchup.
              GD3Design
              I edited my post with 'bad info'. Glad you posted this...I had no idea connector worked with SU. Going to go give it a try now! cheers
