    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 59.4k Views 17 Watching
    • fredo6F Offline
      fredo6
      The information on FredoGuides is maintained on the Plugin Home Page of FredoGuides. This is also where you can download the RBZ file.
      • LibFredo6: v15.6a or above
      • Usage: Free for the time being
      • Expiration on: 31 Dec 2026
      TO NEWCOMERS: If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      FredoGuides is a new extension dealing with Sketchup Guides (also called Construction lines and points).
      Version 1.5 includes the following features:
      • Guide Protection: Mark guides to prevent their deletion by the 'Delete Guides' command of Sketchup.
      • Toggle Visibility: Toggle visibility of all guides in the model. This setting can be saved by Scene.
      • Guide Color: Assign a color to guide lines and guide points. This setting can be saved by Scene.
      Credit: all toolbar icons and button images by JClements
      NO user manual for the time being. Have a look at the video and Quick Start section at the plugin page.
      1) Guides Protection
      A quick introduction to the Protection of Guides
      2) Guides Visibility and Color
      ...and how to assign them to scenes.
        sitthikorn
        Hi, Fredo Thank you for your create this extension.
        I would like to feedback for FreoGuides like this...
        when I make a marking guide inside the component and click protect it then I save component and reload it places to the model. The Protection can not protect the guide when I click delete guides (Edit>delete guides). That I think it should protect the guide in components after save as together.
        Thank you
        Sitthikorn N.
        • fredo6F Offline
          fredo6
          Not very clear to me. Could you post the model so that I understand.
          Fredo
          • fredo6F Offline
            fredo6
            NEW RELEASE: FredoGuides v1.1b - 25 Dec 19
            Requirement: LibFredo6 9.5
            FredoGuides v1.1b fixes a serious bug preventing to protect guides if done right after opening Sketchup. So it is advised to migrate to this version
            Home Page of FredoGuides[/color][/b] for information and Download.
            Main post of this FredoGuides thread.
            • fredo6F Offline
              fredo6
              NEW RELEASE: FredoGuides v1.1c - 25 Dec 19
              FredoGuides v1.1c fixes another serious bug preventing to protect guides if done right after opening a Sketchup file containing protected guidelines. So it is advised to migrate to this version
              • N Offline
                nini007
                Bonjour Fredo,
                Ce plugin est formidable et d'une utilité primordiale à couplé avec celui de D. Bur "Projections".
                Je n'arrive pas Ă  changer la couleur des guides, est-ce un bogue ?!?
                Ce qui serait utile c'est de pouvoir mettre certain guide dans un groupe ou composant et pouvoir changer la couleur des guides uniquement ceux qui sont dans un groupe ou composant et pouvoir avoir plusieurs couleurs selon l'importance du guide.
                Bravo pour tous ses plugins qui simplifient la vie, vos plugins sont incontournables.
                Meilleures salutations
                • fredo6F Offline
                  fredo6
                  Unfortunately, Sketchup does only support a SINGLE color for ALL guides...
                  • OxerO Offline
                    Oxer
                    Hi and Happy New Year!!
                    The Spanish Language file:
                    FredoGuides_ES.lang.zip
                    [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                    • fredo6F Offline
                      fredo6
                      Many thanks. I integrate in the next version.
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: FredoGuides v1.1d - 05 Jan 20
                        FredoGuides v1.1d includes the Spanish translation by Oxer.
                          I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
                            adorian
                            HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
                            I tried everything, including installing the new library but the window keeps coming!
                            • fredo6F Offline
                              fredo6
                              NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
                              FredoGuides v1.1e extends the validity.
                              • Didier BurD Offline
                                Didier Bur
                                Thanks Fredo, Problem solved.
                                P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
                                DB
                                • fredo6F Offline
                                  fredo6
                                  Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
                                  • JClementsJ Offline
                                    JClements
                                    Before I updated I had the same issue.
                                    I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
                                    • fredo6F Offline
                                      fredo6
                                      This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
                                      • kenK Offline
                                        ken
                                        Fredo
                                        When ever I right click on any object, I get the attached error message.
                                        Thank you Fredo, the new install solved the problem.
                                        • fredo6F Offline
                                          fredo6
                                          NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                                          FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                                          **Home Page of FredoGuides** for information and Download.
                                          • P Offline
                                            penumbra
                                            I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                                            • 1 / 3
