    Follow me into different radius
    30 Posts 4 Posters 5.2k Views 4 Watching
      Does the white one look more like what you want?
      curviloft test.skp
        Leggy
        exactly, is it to do with the order you pick the lines?
          No. The bottom arc has 24 segments so I divided the straight lines on the sides and top so there is a total of 24 segments up each side (including the segments in the arcs at the top.
            Leggy
            how did you do that?
              Do what? Divide the edges? I right clicked on an edge, selected Divide and then entered the correct number.
                Leggy
                Clever , the problem with the video is the curser leaves the screen so you can’t see what he clicked
                  Which video are you referring to?
                    Leggy
                    The one from box
                      Leggy
                      The one from box
                        The only things I saw where the cursor wasn't visible was when he made a group after context clicking on the selected geometry and then when he moved the cursor to bring the Entity Info panel up to show that it's a solid group.
                        • 2 / 2
