    Follow me into different radius
    30 Posts 4 Posters 5.5k Views 4 Watching
      Leggy
      Hi I’m trying to make a cover on a 90 angle , but the 2 sides have different radius, how can i blend the 2 together , thinking of follow me some how
      Maybe do the longer radius around the 90 angle and then scale down?
        Leggy
        The longer side radius needs to be twice the size of the shorter one
          Leggy
            Leggy
              Leggy
              Sorry, says the file is to large, changed it down and still wont go through
              Thanks for your patience
                Leggy
                Hope this helps
                • BoxB Offline
                  Since you seem to be having problems adding an Image, is it this sort of thing you are after?
                    Leggy
                    Yes but a radius in the corner where they meet, so it blends through
                    Thanks for your time
                    • BoxB Offline
                      It can be done manually but it's much easier with Curviloft and Joint Push Pull.
                      One little note here, By using the center inference and magenta the small radius will be half the large one.
                        Leggy
                        Genius !!!!!!
                        Thanks so much, you make it look so easy
                        • BoxB Offline
                          It's only genius if it is clear enough for you to follow, otherwise it is just speed modelling which isn't very helpful. 😉
                          There are various other ways to do something similar depending on the actual result you need. If needed you can still add an image as there may be a better option.
                            Leggy
                            No that was perfect
                            I had curviloft on my old pc and forgot all about it
                            Thanks alot
                              Leggy
                              hi im getting this message
                                Leggy
                                here's the dwg
                                may help
                                • fredo6F Offline
                                  fredo6
                                  For Curviloft to operate correctly, you need to select only the external contours, not the inner corner edges. Watch the short video by Box again.
                                  Fredo
                                    Leggy
                                    Aha ok thanks for that ill try again on Monday
                                    • BoxB Offline
                                      For a bit of clarity, in my gif you see me select all of it and show that it doesn't work as it highlights too many edges, then I hold down shift to deselect the corner faces. You could also activate the tool with nothing selected and just click on the edges you need.
                                        Leggy
                                        hi I followed your example and got this, any ideas
                                        thanks so much for your time
                                          Why don't you upload the SKP file so we can see what you started with?
                                            Leggy
                                            here you are
                                            curviloft test.skp
                                            • 1 / 2
