    Follow me into different radius
    30 Posts 4 Posters 6.1k Views 4 Watching
      Leggy
        Leggy
          Leggy
          Sorry, says the file is to large, changed it down and still wont go through
          Thanks for your patience
            Leggy
            Hope this helps
            • BoxB Offline
              Since you seem to be having problems adding an Image, is it this sort of thing you are after?
                Leggy
                Yes but a radius in the corner where they meet, so it blends through
                Thanks for your time
                • BoxB Offline
                  It can be done manually but it's much easier with Curviloft and Joint Push Pull.
                  One little note here, By using the center inference and magenta the small radius will be half the large one.
                    Leggy
                    Genius !!!!!!
                    Thanks so much, you make it look so easy
                    • BoxB Offline
                      It's only genius if it is clear enough for you to follow, otherwise it is just speed modelling which isn't very helpful. πŸ˜‰
                      There are various other ways to do something similar depending on the actual result you need. If needed you can still add an image as there may be a better option.
                        Leggy
                        No that was perfect
                        I had curviloft on my old pc and forgot all about it
                        Thanks alot
                          Leggy
                          hi im getting this message
                            Leggy
                            here's the dwg
                            may help
                            • fredo6F Offline
                              For Curviloft to operate correctly, you need to select only the external contours, not the inner corner edges. Watch the short video by Box again.
                                Leggy
                                Aha ok thanks for that ill try again on Monday
                                • BoxB Offline
                                  For a bit of clarity, in my gif you see me select all of it and show that it doesn't work as it highlights too many edges, then I hold down shift to deselect the corner faces. You could also activate the tool with nothing selected and just click on the edges you need.
                                    Leggy
                                    hi I followed your example and got this, any ideas
                                    thanks so much for your time
                                      Why don't you upload the SKP file so we can see what you started with?
                                        Leggy
                                        here you are
                                        curviloft test.skp
                                          Does the white one look more like what you want?
                                          curviloft test.skp
                                            Leggy
                                            exactly, is it to do with the order you pick the lines?
