    3-in one window
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    7 Posts 3 Posters 10.3k Views 3 Watching
    • Epix3DE Offline
      Epix3D
      How would you go about to make this kind of window?
      • halroachH Offline
        halroach
        Hey Epix,
        It's not a total super convenient solution yet, but you can combine windows like in the following video:
        FlexTools - Super Quick Windows, Doors, Slats...
        • HornOxxH Offline
          HornOxx
          hi - I'm not sure it's what you're asking or looking for.
          Usually I use my own standard window components. I have optimized these windows a bit for my own following rendering process. If I have to, I vary the thicknesses of the mounting frames and the opening frames or any othe detailing. These window components I copy-paste then into the already done simple self-cutting opening components...
          Window.skp
          never trust a skinny cook
          • Epix3DE Offline
            Epix3D
            @halroach said:
            Hey Epix,
            Thank you Halroach. I knew I´d seen this video before. Just what I was looking for 👍
            • Epix3DE Offline
              Epix3D
              I have another question..
              Is it possible to adjust lenght/widh of sill beyond the interactive click length?
              • halroachH Offline
                halroach
                Yes, of course!
                1. Look for the setting: "(Interact Tool) Protrusions 0 Or"
                  This will extend the sill to the sides. If it doesn't extend to the new length, use the interact tool once or twice to get it to extend again.
                2. You can change how the sill extends outward or inward with the "Out" and "In" settings - Note that for the sill to be correctly positioned so that it is flush with the wall when In and Out are set to 0, you must set the "Wall - Thickness" so it matches the wall you are placing the window on.
                • Epix3DE Offline
                  Epix3D
                  Super Halroach! Actually I allready found/tested that setting but did not click interact twice.
