    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 14.5k Views 8 Watching
    • D
      Dprince
      Hey guys quick can anyone recommend a plugin of software i can use to do render walkthroughs. im currently using sketchup pro and vray 3.4
      • soloS
        solo
        https://enscape3d.com/
        http://www.solos-art.com
        • ntxdaveN
          ntxdave
          You can also look at Shapespark
          Press F1...thank me later
          • D
            Dprince
            does enscape adapt the material settings from vray when doing the walkthrough rendering?
            • soloS
              solo
              No, Enscape has it's own material system, does not adapt Vray materials, very simple and fast software to achieve animation and VR work
              • andybotA
                andybot
                I've moved from V-Ray to Enscape recently for walk-throughs, and can highly recommend it!
                • D
                  Dprince
                  I keep getting this error when i try to run enscape
                  • soloS
                    solo
                    The warning has to do with your GPU, I assume you are on a laptop with an Intel integrated GPU which is not good enough to work with Enscape.
                    • D
                      Dprince
                      oh ok. i guess i can only use this when i upgrade. any idea how i can do the walkthrough with Vray?
                      • soloS
                        solo
                        On your system I doubt it, you would need a week to render it if indeed it was even possible, sorry mate but your machine is just not suited for such things.
                        • ntxdaveN
                          ntxdave
                          Once again, I would suggest you take a look at Shapespark I think it might do what you are looking for. Yes, they have their own material handling as well.
                          • D
                            Dprince
                            for shapespaek can i save the online walkthrough as a video?
                            • D
                              Dprince
                              @pbacot said:
                              Dprince,
                              Are you running Enscape on a Mac with BootCamp? Anyway if on a Mac see if you can select the GPU by turning off Automatic graphics switching in the Energy Saver settings. It will make the computer use a higher-performing card if you have one. Of course the card might still not be up to Enscape standards.
                              im using a windows computer
                              • pbacotP
                                Dprince,
                                • ntxdaveN
                                  ntxdave
                                  I do not think so. The output is for viewing in HTML/WebGL and VR.
                                  • D
                                    Dprince
                                    OK THANKS. thats not exactly what i want to do it has to be in video format and not available to just online viewing
                                    • pbacotP
                                      Sorry, I read your profile and thought it was the Mac.
                                      • D
                                        Dprince
                                        I would still like to know how to do the walk through using vray. no matter how long it takes to render
                                        • V
                                          valerostudio
                                          This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
                                          • V
                                            valerostudio
                                            VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
                                            Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
                                            Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
                                            There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
                                            Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
                                            • 1 / 2
