    Shiny Metal
    23 Posts 11 Posters 3.7k Views 11 Watching
      A little experimentation. Looks a little too new but it was an interesting exercise.
      Maybe better in black and white?
      FWIW, the handles are 5/8 in. max diameter and a little over 6 in. long. Threads are 3/8-16. Modeled entirely in SketchUp.
      • pbacotP Offline
        Looks great! Including the knurled part!
          Looks like a fine chrome/stainless steel.
          • tuna1957T Offline
            tuna1957
            Great model ! Two different "grungy" metal textures would really push it over the top. The "blocks" that hold the tap were a darker finish than the handles on a lot of these I've seen in years past. πŸ‘ πŸ‘ πŸ‘
              Thank you.
              Charles, I did think about using different materials for the different parts and adding some grunge but at this stage, I'm going to leave it as is. So much to model, so little time. πŸ˜‰
              • ntxdaveN Offline
                ntxdave
                Really like these renders. They look more like a photo than a render. πŸ‘ πŸ‘
                I wish I could get some of the metal in my renders to look that realistic.
                Press F1...thank me later
                  Thanks Dave. It's just a preset in Kerkythea although I did edit it to make it a little less polished. I think one thing that gets missed in a lot of renders of metallic or other reflective surfaces is the lack of things to reflect. In these there's the base the model is laying on, there are the two spot lights and a couple of blocks set up out of view of the camera. The rear light is blue. One of the blocks is painted dark blue and the other dark gray.(I'm not including yours because I don't know.)
                  Many times I see renders of models but they are just floating in space. Those always look weird to me.
                    Nice work Dave, looks great πŸ‘ I agree with you that it needs a bit of grunge . How was the knurling achieved? is it a texture or in the model? I see the knurling fades out as it would be in real world machining.
                      Hi Liam. Thanks.
                      The knurling is modeled instead of a texture. Adds a bit to the file size but since I used components for the diamonds, it's only about 2.5 Mb.
                        Was the knurling achieved working from a helix, then intersecting faces (or Similar)..........? If not that technique can you share?
                        Cheers
                          To be honest, I don't remember exactly. My memory is a little foggy because I drew the knurling for a little brass pin about three years ago. I reused it for this tap wrench. As I recall, though, I started with a circle with 48 sides and used that as a reference for drawing a small diamond that I made into a component which was then copied to make a ring of diamonds (a diamond ring. πŸ˜› ) which I then copied and rotated half a tick to make the interlocking ring. Then it was just a case of making a linear array of the diamond rings.
                          https://farm2.staticflickr.com/1456/24362529189_867d063cc3.jpg
                          I had to make the knurling longer and of course increase the overall diameter a bit for the tap wrench and then modify some of the diamonds where the knurling runs into the tapered section as well as at the opposite end. You can see where it runs into the taper, below.
                          https://farm5.staticflickr.com/4815/46663833111_660dec7bdb.jpg
                            Nice work and thanks πŸ˜„
                              Thank you, sir.
                                And always rendered with Kerkythea ?
                                • HornOxxH Offline
                                  HornOxx
                                  😲 no matter if the metal looks too new or not or any HDRI background or not - PERFEKT !! πŸ‘ πŸ‘ What is it and what is it for?
                                  never trust a skinny cook
                                    Yes, Pilou. It was rendered in KT.
                                    Hornoxx, thank you very much. It's what we'd call a tap wrench. It holds the square shank of a tap for threading holes. It's more common to see the the T-handled variety and there are a few other styles as well.
                                    • majidM Offline
                                      majid
                                      Good to see you are still loyal to KT!
                                        No point changing horses when this one will still run. πŸ˜‰
                                        • jo-keJ Offline
                                          jo-ke
                                          still using KT/Twilight for 10 years now
                                          http://www.zz7.de
                                          • majidM Offline
                                            majid
                                            My Gosh!
                                            • 1 / 2
