    Shiny Metal
    23 Posts 11 Posters 9.1k Views 11 Watching
      To be honest, I don't remember exactly. My memory is a little foggy because I drew the knurling for a little brass pin about three years ago. I reused it for this tap wrench. As I recall, though, I started with a circle with 48 sides and used that as a reference for drawing a small diamond that I made into a component which was then copied to make a ring of diamonds (a diamond ring. πŸ˜› ) which I then copied and rotated half a tick to make the interlocking ring. Then it was just a case of making a linear array of the diamond rings.
      https://farm2.staticflickr.com/1456/24362529189_867d063cc3.jpg
      I had to make the knurling longer and of course increase the overall diameter a bit for the tap wrench and then modify some of the diamonds where the knurling runs into the tapered section as well as at the opposite end. You can see where it runs into the taper, below.
      https://farm5.staticflickr.com/4815/46663833111_660dec7bdb.jpg
      • L
        Nice work and thanks πŸ˜„
          Thank you, sir.
            And always rendered with Kerkythea ?
            • HornOxxH
              HornOxx
              😲 no matter if the metal looks too new or not or any HDRI background or not - PERFEKT !! πŸ‘ πŸ‘ What is it and what is it for?
              never trust a skinny cook
                Yes, Pilou. It was rendered in KT.
                Hornoxx, thank you very much. It's what we'd call a tap wrench. It holds the square shank of a tap for threading holes. It's more common to see the the T-handled variety and there are a few other styles as well.
                • majidM
                  majid
                  Good to see you are still loyal to KT!
                    No point changing horses when this one will still run. πŸ˜‰
                    • jo-keJ
                      jo-ke
                      still using KT/Twilight for 10 years now
                      http://www.zz7.de
                      • majidM
                        majid
                        My Gosh!
                          I guess it's been at least that long with KT for me, too. Actually longer since I started with it before the 2008 version.
                          • majidM
                            majid
                            My journey to photo-real renders began using KT2007 version and 2008 version was a great leap forward. I was always know about the "phess" ( I guess it has been the great ancestor of KT)
                            • hellnbakH
                              hellnbak
                              Dave,
                              Beautiful work πŸ‘
                              BTW, I'll give you five bucks for a copy of all your texture libraries (mainly the wood stuff, I really suck at wood stuff and can never find what I need anywhere online).
                              I'm talking cash!
                              Steve
