    Shiny Metal
    23 Posts 11 Posters 9.0k Views 11 Watching
      Thanks Dave. It's just a preset in Kerkythea although I did edit it to make it a little less polished. I think one thing that gets missed in a lot of renders of metallic or other reflective surfaces is the lack of things to reflect. In these there's the base the model is laying on, there are the two spot lights and a couple of blocks set up out of view of the camera. The rear light is blue. One of the blocks is painted dark blue and the other dark gray.(I'm not including yours because I don't know.)
      Many times I see renders of models but they are just floating in space. Those always look weird to me.
        Nice work Dave, looks great πŸ‘ I agree with you that it needs a bit of grunge . How was the knurling achieved? is it a texture or in the model? I see the knurling fades out as it would be in real world machining.
          Hi Liam. Thanks.
          The knurling is modeled instead of a texture. Adds a bit to the file size but since I used components for the diamonds, it's only about 2.5 Mb.
            Was the knurling achieved working from a helix, then intersecting faces (or Similar)..........? If not that technique can you share?
            Cheers
              To be honest, I don't remember exactly. My memory is a little foggy because I drew the knurling for a little brass pin about three years ago. I reused it for this tap wrench. As I recall, though, I started with a circle with 48 sides and used that as a reference for drawing a small diamond that I made into a component which was then copied to make a ring of diamonds (a diamond ring. πŸ˜› ) which I then copied and rotated half a tick to make the interlocking ring. Then it was just a case of making a linear array of the diamond rings.
              https://farm2.staticflickr.com/1456/24362529189_867d063cc3.jpg
              I had to make the knurling longer and of course increase the overall diameter a bit for the tap wrench and then modify some of the diamonds where the knurling runs into the tapered section as well as at the opposite end. You can see where it runs into the taper, below.
              https://farm5.staticflickr.com/4815/46663833111_660dec7bdb.jpg
                Nice work and thanks πŸ˜„
                  Thank you, sir.
                    And always rendered with Kerkythea ?
                    • HornOxxH Offline
                      HornOxx
                      😲 no matter if the metal looks too new or not or any HDRI background or not - PERFEKT !! πŸ‘ πŸ‘ What is it and what is it for?
                      never trust a skinny cook
                        Yes, Pilou. It was rendered in KT.
                        Hornoxx, thank you very much. It's what we'd call a tap wrench. It holds the square shank of a tap for threading holes. It's more common to see the the T-handled variety and there are a few other styles as well.
                        • majidM Offline
                          majid
                          Good to see you are still loyal to KT!
                            No point changing horses when this one will still run. πŸ˜‰
                            • jo-keJ Offline
                              jo-ke
                              still using KT/Twilight for 10 years now
                              http://www.zz7.de
                              • majidM Offline
                                majid
                                My Gosh!
                                  I guess it's been at least that long with KT for me, too. Actually longer since I started with it before the 2008 version.
                                  • majidM Offline
                                    majid
                                    My journey to photo-real renders began using KT2007 version and 2008 version was a great leap forward. I was always know about the "phess" ( I guess it has been the great ancestor of KT)
                                    • hellnbakH Offline
                                      hellnbak
                                      Dave,
                                      Beautiful work πŸ‘
                                      BTW, I'll give you five bucks for a copy of all your texture libraries (mainly the wood stuff, I really suck at wood stuff and can never find what I need anywhere online).
                                      I'm talking cash!
                                      Steve
