    SkethUcation privacy https
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 12 Posters 37.9k Views 12 Watching
    • jujuJ Offline
      juju
      This morning, when checking in at sketchUcation, I get a privacy error problem, yesterday evening it was still fine. I have not done any updates to my browser (but it may have updated silently in the background).
      I was pretty sure that sketchUcation was previously sorted in terms of https vs regular http or www - did anything change in the last 12 hours?
      • F Offline
        faust07
        The same here with edge (Windows 10 Pro) - but with IE (Windows 7 Pro) not..
        • sketch3d.deS Offline
          sketch3d.de
          the used COMODO certificate is expired (21. November 2018, 23:59:59 GMT), clicking on the lock symbol (or something similar) in the browser address bar should reveal according infos.
            rv1974
            Today I've got a constant 'Your clock is ahead' error on android phone
              Same for me "Certicat invalide"! ...Continue anyway...on each page so some painful!
              Smiley affected!
                Refresh your browsers...
                Should be OK now.
                Rich/Gábor changed the Certificate system - which broke !
                But I think it's now all pukka...
                  Works fine now! 👍
                  • sfto1S Offline
                    sfto1
                    works fine here too!
                    • K Offline
                      kaas
                      ditto again with Bitdefender
                      • jujuJ Offline
                        juju
                        Thanks to all involved, working fine again now!
                          The problem has returned! ❗ ❗ ❗
                          • jujuJ Offline
                            juju
                            And seems to be have been solved again as well ❗ ❗ ❗
                            (I'm not seeing the problem now, thus the assumption.)
                            • soloS Offline
                              solo
                              SCF only works with http and not https now.
                              http://www.solos-art.com
                              • BoxB Offline
                                No Solo, you need to refresh your browser if that is the case.
                                Unless of course different servers have different results.
                                • jujuJ Offline
                                  juju
                                  https here
                                    It still works fine for me with https [if I try http, then my browser uses https anyway !]
                                    Maybe Rich/Gábor have been tweaking the certification again !
                                    • soloS Offline
                                      solo
                                        Solo
                                        Have you cleared your browser's cache ?
                                        • soloS Offline
                                          solo
                                          @tig said:
                                          Solo
                                          Yes, just did and still get same results.
                                            I assume you are on Chrome ?
                                            • 1 / 3
