    SkethUcation privacy https
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 12 Posters 38.0k Views 12 Watching
      Refresh your browsers...
      Should be OK now.
      Rich/Gรกbor changed the Certificate system - which broke !
      But I think it's now all pukka...
        Works fine now! ๐Ÿ‘
        • sfto1S Offline
          sfto1
          works fine here too!
            kaas
            ditto again with Bitdefender
            • jujuJ Offline
              juju
              Thanks to all involved, working fine again now!
                The problem has returned! โ— โ— โ—
                • jujuJ Offline
                  juju
                  And seems to be have been solved again as well โ— โ— โ—
                  (I'm not seeing the problem now, thus the assumption.)
                  • soloS Offline
                    SCF only works with http and not https now.
                    • BoxB Offline
                      No Solo, you need to refresh your browser if that is the case.
                      Unless of course different servers have different results.
                      • jujuJ Offline
                        juju
                        https here
                          It still works fine for me with https [if I try http, then my browser uses https anyway !]
                          Maybe Rich/Gรกbor have been tweaking the certification again !
                          • soloS Offline
                              Solo
                              Have you cleared your browser's cache ?
                              • soloS Offline
                                @tig said:
                                Solo
                                Yes, just did and still get same results.
                                  I assume you are on Chrome ?
                                  • soloS Offline
                                    I get the same result with Edge
                                      Chrome and Edge seem to use similar protocols...
                                      But while my Chrome was working OK, now I see Edge has this issue again...
                                      Saying the Certificate has been revoked !
                                      WTF ?
                                      I've PM'd Gรกbor/Rich...
                                        Same bad result with Opera, Chrome, IE, Edge...! ๐Ÿ˜ฎ
                                          Rich/Gรกbor are investigating...
                                          Works fine for me with Firefox and Chrome, but a certificate error with IE & Edge...
                                          ๐Ÿ˜ฒ
                                            You are lucky : here it's the total blockade with any navigators for certificates! ๐Ÿ˜ฒ
                                            someone give me that! ๐Ÿ˜‰
                                            https://letsencrypt.org/
                                            "That not only gets rid of paying for it but it also simplifies managing them when they expire as well which can also be a pain."
                                            Have fun coding!
                                            • 1 / 3
