SkethUcation privacy https
This morning, when checking in at sketchUcation, I get a privacy error problem, yesterday evening it was still fine. I have not done any updates to my browser (but it may have updated silently in the background).
I was pretty sure that sketchUcation was previously sorted in terms of https vs regular http or www - did anything change in the last 12 hours?
The same here with edge (Windows 10 Pro) - but with IE (Windows 7 Pro) not..
the used COMODO certificate is expired (21. November 2018, 23:59:59 GMT), clicking on the lock symbol (or something similar) in the browser address bar should reveal according infos.
Today I've got a constant 'Your clock is ahead' error on android phone
Same for me "Certicat invalide"! ...Continue anyway...on each page so some painful!
Smiley affected!
Refresh your browsers...
Should be OK now.
Rich/Gábor changed the Certificate system - which broke !
But I think it's now all pukka... -
Works fine now!
works fine here too!
ditto again with Bitdefender
Thanks to all involved, working fine again now!
The problem has returned!
And seems to be have been solved again as well
(I'm not seeing the problem now, thus the assumption.)
SCF only works with http and not https now.
No Solo, you need to refresh your browser if that is the case.
Unless of course different servers have different results. -
It still works fine for me with https [if I try http, then my browser uses https anyway !]
Maybe Rich/Gábor have been tweaking the certification again ! -
Solo
Have you cleared your browser's cache ?
I assume you are on Chrome ?
Here's what I got just a minute ago...
