    SkethUcation privacy https
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 12 Posters 39.1k Views 12 Watching
    • sketch3d.deS
      sketch3d.de
      the used COMODO certificate is expired (21. November 2018, 23:59:59 GMT), clicking on the lock symbol (or something similar) in the browser address bar should reveal according infos.
        rv1974
        Today I've got a constant 'Your clock is ahead' error on android phone
          Same for me "Certicat invalide"! ...Continue anyway...on each page so some painful!
          Smiley affected!
            Refresh your browsers...
            Should be OK now.
            Rich/Gábor changed the Certificate system - which broke !
            But I think it's now all pukka...
              Works fine now! 👍
              • sfto1S
                sfto1
                works fine here too!
                • K
                  kaas
                  ditto again with Bitdefender
                  • jujuJ
                    juju
                    Thanks to all involved, working fine again now!
                      The problem has returned! ❗ ❗ ❗
                      • jujuJ
                        juju
                        And seems to be have been solved again as well ❗ ❗ ❗
                        (I'm not seeing the problem now, thus the assumption.)
                        • soloS
                          SCF only works with http and not https now.
                          • BoxB
                            No Solo, you need to refresh your browser if that is the case.
                            Unless of course different servers have different results.
                            • jujuJ
                              juju
                              https here
                                It still works fine for me with https [if I try http, then my browser uses https anyway !]
                                Maybe Rich/Gábor have been tweaking the certification again !
                                • soloS
                                    Solo
                                    Have you cleared your browser's cache ?
                                    • soloS
                                      @tig said:
                                      Solo
                                      Yes, just did and still get same results.
                                        I assume you are on Chrome ?
                                        • soloS
                                          I get the same result with Edge
                                            Chrome and Edge seem to use similar protocols...
                                            But while my Chrome was working OK, now I see Edge has this issue again...
                                            Saying the Certificate has been revoked !
                                            WTF ?
                                            I've PM'd Gábor/Rich...
                                            • 1 / 3
