    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Flowify problems
    extensions
    70 Posts 25 Posters 38.6k Views 25 Watching
      Better to cover the maximum range! πŸ˜‰
      It's the same time to make (1 second) πŸ€“
      • jujuJ Offline
        juju
        Yeah, but if you ask something that seems outrageous then people will be less likely to follow the advise.
          They want advices so they will make all for that! πŸ˜„
            aamirkaiser
            @pilou said:
            But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
            Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
            Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
            then Segmentor of Polyline (upper & bottom curves)
            (for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
            then you will obtain that in Curviloft (third icon "Skin contour" )
            [attachment=3:26d9tppe]<!-- ia3 -->segmentor.jpg<!-- ia3 -->[/attachment:26d9tppe]
            You will obtain a better result! β˜€ ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
            [attachment=2:26d9tppe]<!-- ia2 -->yours better.jpg<!-- ia2 -->[/attachment:26d9tppe]
            Ps You must also clean your original object! πŸ˜„
            [attachment=1:26d9tppe]<!-- ia1 -->clean_line.jpg<!-- ia1 -->[/attachment:26d9tppe]
            I have a problem utilizing the flowify plugin, and I think its the density that's the problem, can you tell me a work around for that issue... I have used flowify successfully multiple times so I know the selection or the group isn't the problem... It would be wonderful If you could help me out...
            Please help
              akash das
              hi i am really struggling to use flowify, inspite of making sure of all the group of
              1. curve surface
              2. flat surface (a rectangle)
              3. connecting lines
              4. the module with raw surface
              i have checked all the perimeters it doesn't work with all kind of models i feel.
              kindly help
              • cottyC Offline
                cotty
                You can upload an example model so that we can have a deeper look...
                my SketchUp gallery
                • Y Offline
                  yashmishra
                  a request for help : have been trying to get this right for past 2 hours everytime a different error is coming up. please could anyone help me out.
                  help me flowify
                  • cottyC Offline
                    cotty
                    You need a quad mesh to be able to map it to the flat surface... but there will more work to do to make it a "nice" solid...
                    Untitled2.skp
                    my SketchUp gallery
                    • Y Offline
                      yashmishra
                      [attachment=1:1tgwd386]<!-- ia1 -->untitled2.JPG<!-- ia1 -->[/attachment:1tgwd386]
                      could you please explain in detail why a quad mesh is required?
                      • cottyC Offline
                        cotty
                        Because it's a requirement in the second sentence of the plugin description?
                        "The extension bends geometry along quad surfaces."
                        my SketchUp gallery
                          You can't project something with Flowify on a complete sphere 3D!
                          But yes if you make a little triming somewhere like that!
                          You have now a "quad" surface! πŸ˜‰
                          • P Offline
                            paritoshaj
                            Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
                            source geometry must contain raw faces.skp
                            • cottyC Offline
                              cotty
                              After exploding the pyramids in the source geometry group, it's working...
                              my SketchUp gallery
                                arkiduckling
                                hi I have an issue also with flowify, it is not working and I dont know if it is because of my mistakes or plugin's issue because when i checked my extension manager, there's a text in the flowify says UNSIGNED. May I know what does it mean and if that was the reason why i couldnt work with flowify πŸ˜„)) thank you
                                • cottyC Offline
                                  cotty
                                  It's not the reason πŸ˜‰
                                  you can upload the model and we will have a look at it...
                                  my SketchUp gallery
                                    @arkiduckling said:
                                    ...there's a text in the flowify says UNSIGNED.
                                    Signed or unsigned has no bearing on the functionality of the extension.
                                    As Cotty, suggests, share your .skp file so we can see what you are working with and what steps you need to take to sort it out.
                                      ravindulk94
                                      @optimaforever said:
                                      I have a strange behaviour too...
                                      The flowify command generates a huge model, with an array of sectional faces.
                                      [attachment=2:17yhee20]<!-- ia2 -->flowify A.JPG<!-- ia2 -->[/attachment:17yhee20]
                                      First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
                                      [attachment=1:17yhee20]<!-- ia1 -->flowify B.JPG<!-- ia1 -->[/attachment:17yhee20]
                                      The resulting groups from the flowify command
                                      I succeeded all the other meshes with the same method but here I've got a bug...
                                      [attachment=0:17yhee20]<!-- ia0 -->flowify bug.skp<!-- ia0 -->[/attachment:17yhee20]
                                      did you find any solution for this error?
                                        What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
                                          MrKrabs
                                          can someone help me out with flowify? I canΒ΄t get it to work properly
                                          Thanks!
                                          Flowify_problem.skp
                                          • cottyC Offline
                                            cotty
                                            From the instructions...
                                            Your target surface isn't suitable.
                                            my SketchUp gallery
                                            • 2 / 4
