    Flowify problems
    extensions
    70 Posts 25 Posters 47.6k Views 25 Watching
    • H Offline
      hellolouise
      Thank you so much that is very helpful!
      I will try again πŸ˜„)
      • O Offline
        optimaforever
        I have a strange behaviour too...
        The flowify command generates a huge model, with an array of sectional faces.
        The source material
        First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
        And the result
        The resulting groups from the flowify command
        I succeeded all the other meshes with the same method but here I've got a bug...
        The skp
        • newnoobN Offline
          newnoob
          I am using flowify for the first time with very simple geometry but I get the error message
          " INPUT ERROR: Error while parsing the projection grid".
          https://sketchucation.com/forums/download/file.php?mode=view&id=158854&sid=d47475267b2b642d948ff06d550663e6
          I have checked my model several times but I don't understand what I do wrong. I have also named all the groups like Pilou in his first post.
          If someone could tell me what i do wrong I'd appreciate it.
          flowify.skp
            Your Start Surface C must be a "rectangular" form and not the same surface as the original object ! πŸ˜‰
            • newnoobN Offline
              newnoob
              Ahhh, "rectangular", got it. Now it's working. I somehow missed that. I thought "plane".
              Many Thanks Pilou! I'm glad you are still around!
                CREATIVE WIERDO
                Hello.
                I have a problem with Flowify tool. Please check my file because i have made my groups correctly i think and when i choose the command flowify -> impose grid, the grid doesnt appear.
                What am i doing wrong? I saw a video on youtube that says that if i have done my groups correctly a grid must appear.
                Thanks for the help.
                Help needed.skp
                  What version of SketchUp? Your profile says 2018 Free/Make but that doesn't exist.
                    Can you post your skp file in "save as" V6 for more compatibilities with previous version for have some help! πŸ˜‰
                    • jujuJ Offline
                      juju
                      I'm not sure how useful this would be these days, the earliest version I've seen people working on (recently) is version 8, rather ask people to post in SU 2017 version / format. Plus you're already on SU 2017 Make...
                        Better to cover the maximum range! πŸ˜‰
                        It's the same time to make (1 second) πŸ€“
                        • jujuJ Offline
                          juju
                          Yeah, but if you ask something that seems outrageous then people will be less likely to follow the advise.
                            They want advices so they will make all for that! πŸ˜„
                              aamirkaiser
                              @pilou said:
                              But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
                              Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
                              Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
                              then Segmentor of Polyline (upper & bottom curves)
                              (for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
                              then you will obtain that in Curviloft (third icon "Skin contour" )
                              [attachment=3:26d9tppe]<!-- ia3 -->segmentor.jpg<!-- ia3 -->[/attachment:26d9tppe]
                              You will obtain a better result! β˜€ ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
                              [attachment=2:26d9tppe]<!-- ia2 -->yours better.jpg<!-- ia2 -->[/attachment:26d9tppe]
                              Ps You must also clean your original object! πŸ˜„
                              [attachment=1:26d9tppe]<!-- ia1 -->clean_line.jpg<!-- ia1 -->[/attachment:26d9tppe]
                              I have a problem utilizing the flowify plugin, and I think its the density that's the problem, can you tell me a work around for that issue... I have used flowify successfully multiple times so I know the selection or the group isn't the problem... It would be wonderful If you could help me out...
                              Please help
                                akash das
                                hi i am really struggling to use flowify, inspite of making sure of all the group of
                                1. curve surface
                                2. flat surface (a rectangle)
                                3. connecting lines
                                4. the module with raw surface
                                i have checked all the perimeters it doesn't work with all kind of models i feel.
                                kindly help
                                • cottyC Offline
                                  cotty
                                  You can upload an example model so that we can have a deeper look...
                                  my SketchUp gallery
                                  • Y Offline
                                    yashmishra
                                    a request for help : have been trying to get this right for past 2 hours everytime a different error is coming up. please could anyone help me out.
                                    help me flowify
                                    • cottyC Offline
                                      cotty
                                      You need a quad mesh to be able to map it to the flat surface... but there will more work to do to make it a "nice" solid...
                                      Untitled2.skp
                                      my SketchUp gallery
                                      • Y Offline
                                        yashmishra
                                        [attachment=1:1tgwd386]<!-- ia1 -->untitled2.JPG<!-- ia1 -->[/attachment:1tgwd386]
                                        could you please explain in detail why a quad mesh is required?
                                        • cottyC Offline
                                          cotty
                                          Because it's a requirement in the second sentence of the plugin description?
                                          "The extension bends geometry along quad surfaces."
                                          my SketchUp gallery
                                            You can't project something with Flowify on a complete sphere 3D!
                                            But yes if you make a little triming somewhere like that!
                                            You have now a "quad" surface! πŸ˜‰
                                            • 2 / 4
