    Flowify problems
    extensions
    70 Posts 25 Posters 50.2k Views 25 Watching
      Your Start Surface C must be a "rectangular" form and not the same surface as the original object ! πŸ˜‰
      • newnoobN
        newnoob
        Ahhh, "rectangular", got it. Now it's working. I somehow missed that. I thought "plane".
        Many Thanks Pilou! I'm glad you are still around!
        • C
          CREATIVE WIERDO
          Hello.
          I have a problem with Flowify tool. Please check my file because i have made my groups correctly i think and when i choose the command flowify -> impose grid, the grid doesnt appear.
          What am i doing wrong? I saw a video on youtube that says that if i have done my groups correctly a grid must appear.
          Thanks for the help.
          Help needed.skp
            What version of SketchUp? Your profile says 2018 Free/Make but that doesn't exist.
              Can you post your skp file in "save as" V6 for more compatibilities with previous version for have some help! πŸ˜‰
              • jujuJ
                juju
                I'm not sure how useful this would be these days, the earliest version I've seen people working on (recently) is version 8, rather ask people to post in SU 2017 version / format. Plus you're already on SU 2017 Make...
                  Better to cover the maximum range! πŸ˜‰
                  It's the same time to make (1 second) πŸ€“
                  • jujuJ
                    juju
                    Yeah, but if you ask something that seems outrageous then people will be less likely to follow the advise.
                      They want advices so they will make all for that! πŸ˜„
                        aamirkaiser
                        @pilou said:
                        But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
                        Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
                        Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
                        then Segmentor of Polyline (upper & bottom curves)
                        (for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
                        then you will obtain that in Curviloft (third icon "Skin contour" )
                        [attachment=3:26d9tppe]<!-- ia3 -->segmentor.jpg<!-- ia3 -->[/attachment:26d9tppe]
                        You will obtain a better result! β˜€ ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
                        [attachment=2:26d9tppe]<!-- ia2 -->yours better.jpg<!-- ia2 -->[/attachment:26d9tppe]
                        Ps You must also clean your original object! πŸ˜„
                        [attachment=1:26d9tppe]<!-- ia1 -->clean_line.jpg<!-- ia1 -->[/attachment:26d9tppe]
                        I have a problem utilizing the flowify plugin, and I think its the density that's the problem, can you tell me a work around for that issue... I have used flowify successfully multiple times so I know the selection or the group isn't the problem... It would be wonderful If you could help me out...
                        Please help
                          akash das
                          hi i am really struggling to use flowify, inspite of making sure of all the group of
                          1. curve surface
                          2. flat surface (a rectangle)
                          3. connecting lines
                          4. the module with raw surface
                          i have checked all the perimeters it doesn't work with all kind of models i feel.
                          kindly help
                          • cottyC
                            cotty
                            You can upload an example model so that we can have a deeper look...
                            my SketchUp gallery
                            • Y
                              yashmishra
                              a request for help : have been trying to get this right for past 2 hours everytime a different error is coming up. please could anyone help me out.
                              help me flowify
                              • cottyC
                                cotty
                                You need a quad mesh to be able to map it to the flat surface... but there will more work to do to make it a "nice" solid...
                                Untitled2.skp
                                my SketchUp gallery
                                • Y
                                  yashmishra
                                  [attachment=1:1tgwd386]<!-- ia1 -->untitled2.JPG<!-- ia1 -->[/attachment:1tgwd386]
                                  could you please explain in detail why a quad mesh is required?
                                  • cottyC
                                    cotty
                                    Because it's a requirement in the second sentence of the plugin description?
                                    "The extension bends geometry along quad surfaces."
                                    my SketchUp gallery
                                      You can't project something with Flowify on a complete sphere 3D!
                                      But yes if you make a little triming somewhere like that!
                                      You have now a "quad" surface! πŸ˜‰
                                      • P
                                        paritoshaj
                                        Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
                                        source geometry must contain raw faces.skp
                                        • cottyC
                                          cotty
                                          After exploding the pyramids in the source geometry group, it's working...
                                          my SketchUp gallery
                                            arkiduckling
                                            hi I have an issue also with flowify, it is not working and I dont know if it is because of my mistakes or plugin's issue because when i checked my extension manager, there's a text in the flowify says UNSIGNED. May I know what does it mean and if that was the reason why i couldnt work with flowify πŸ˜„)) thank you
                                            • 2 / 4
