    Sketchup for Window 64-bit
    8 Posts 6 Posters 1.9k Views 6 Watching
    • G
      garystan
      Hi everybody :
      How much is Sketchup for Windows 64-bit ? I'm planning on upgrading my System.......probably to Windows 10. Thanks. garystan
      • sfto1S
        sfto1
        $695 for 2018 pro
        Free for 2017 make
        • jujuJ
          juju
          Then there is the SketchUp Shop (online only) variant with commercial licence. After all the hoo-haa I'm not finding a link to it on the SketchUp home page...
          • G
            garystan
            sfto1 :
            So....Sketchup 2017 Free...is "FREE". Does it have the same features at Sketchup 8 ?
            Thanks.........garystan
            • sfto1S
              sfto1
              @garystan said:
              sfto1 :
              From what I remember it has the same and more.
              You can install 2017 Make, which is free, alongside SU 8, so you do not have to remove SU 8. You can then decide which is best. I highly recommend that you download and install SU 2017 Make and get used to the newer UI, and I suspect you will enjoy it.
              • S
                slbaumgartner
                There have been numerous bug fixes and improvements between SketchUp 8 and SketchUp Make 2017. Among these are changes in the Ruby API that may cause some plugins/extensions to fail. But any plugin author who is still active will have updated their code to handle the changes, so it is not usual to be unable to find a plugin revision that will work in 2017. In fact, it is becoming more common to find extensions that the authors no longer support SU 8 due to these changes!
                • sketch3d.deS
                  sketch3d.de
                  @garystan said:
                  sfto1 :
                  Discontinued SketchUp Make 2017 (desktop) as well as the new SketchUp Free (browser) are free for non-commercial purposes only.
                  Commercial work requires a license of SketchUp Pro (desktop) or subscribing SketchUp Shop (browser).
                  • HornOxxH
                    HornOxx
                    ...also "pay"-plugins like Skatter or SubD run unrestricted on 2017 Make
                    never trust a skinny cook
