    ComponentFinder
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    39 Posts 9 Posters 86.4k Views 9 Watching
    • halroachH Offline
      halroach
      Meet ComponentFinder - our new super convenient tool, designed for, not merely browsing your library, but for actually finding the components you need. Easy, fast and all within SketchUp!
      • Enhanced Browsing - Choose the best way to view your components (navigation or flat-files)
      • Powerful Search - Quickly filter through your open tabs and components
      • Zoom In / Zoom Out - See larger or smaller component thumbnails
      • Save Components - Save components into ComponentFinder directly from Sketchup
      • Open multiple tabs at once - Select multiple folders from your local library and add them into ComponentFinder, all at once
      ComponentFinder is an evolution of the FlexTools Favorites Library. It will now work with all components, not only with "flex".
      Coming Soon!
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH Offline
        halroach
        We just launched a beta version of ComponentFinder. Hooray!
        Looking for people to help us test and improve it.
        Be part of it! --> https://flextools.cc/componentfinder-beta/
        And yes, it’s FREE!
        • halroachH Offline
          halroach
          Great video explaining ComponentFinder thanks to Architecture Inspirations
          • jujuJ Offline
            juju
            haha, clever, it integrates with the FlexPack icons, was searching like mad to find it at first as I was expecting a separate new floating icon as one normally finds when installing a new extension...
              chrisik
              i've installed component finder along with the other flextools and activated it. Then i want to add a folder, the windows explorer opens and i can select one but then nothing happens - the component finder window keeps blanc and no components are displayed. i've tried other folders with sketchup models and i also reinstalled the plugin but it doesn't work. i use windows 10/1803 sketchup pro 2018.
              • halroachH Offline
                halroach
                Hi Chrisik,
                Please open the Ruby Console: Window > Ruby Console
                Are you getting any messages there when you try to open a folder?
                Yoni
                • halroachH Offline
                  halroach
                  Hi Juju,
                  Forgive me for the confusion. Glad you found it eventually 😄.
                  I've updated the ComponentFinder page with an entry called FlexTools Integration, and updated the Learn page, showing the toolbar with, and without FlexPack.
                  Does that clears up the confusion?
                    chrisik
                    @halroach said:
                    Hi Chrisik,
                    Yoni
                    No, i don't get any messages.
                    • halroachH Offline
                      halroach
                      Please email me at yoni@flextools.cc so we can troubleshoot this issue further.
                        jkoll66
                        Hello, Component Finder is a great extension. In a future release could you please allow a way to see the file path somewhere? I have 2 folders on different servers containing the same components. One is a personal folder for my components and the other is a user folder. I've on occasion had the wrong folder open in the Component Finder window. Thanks.
                        • halroachH Offline
                          halroach
                          Hi Jkoll, Thanks!
                          When we first started working on ComponentFinder we thought of showing the full path, but we found that it added a lot of unnecessary clutter to the screen, and in most cases it seemed like it's not needed.
                          We may add the possibility of viewing the full path in future versions...
                          If possible, you could try renaming the folders to avoid confusion. If you can't rename, for the time being, you can click on the little hard disk button every now and then which would open the source folder. It would serve as a double-check to make sure you're in the correct place.
                            jkoll66
                            @halroach said:
                            Hi Jkoll, Thanks!
                            The problem is that the contents of my personal folder are Robocopied nightly into the user folder. I can rename the parent folder, but there are child folders that can't be renamed. Maybe you could incorporate a tool tip that flies out from the folder name when you hover over it? Thanks.
                            • EdsonE Offline
                              Edson
                              I installed Component Finder but, since I once had FlexTools installed, it was installed as part of its long toolbar. It did not ask for my license number either.
                              My question is: what files do I have to delete to get rid of the FT toolbar? Since I do not use the other tools I would like to have the short toolbar that shows only Component Finder.
                              Thanks.
                              http://www.mahfuz.arq.br
                              • halroachH Offline
                                halroach
                                Thanks.
                                Hi Edson,
                                To completely remove the rest of the FlexTools toolbar:
                                1. Close Sketchup
                                2. If you have no need for FlexTools at all - Delete the following folder: C:\ProgramData\F3d_FlexTools
                                3. Open Sketchup and reinstall ComponentFinder.
                                4. Open the FlexTools manager (gear icon)
                                5. (re)Activate ComponentFinder with your license key.
                                • EdsonE Offline
                                  Edson
                                  thanks. this is what I had done before. and it worked.
                                  what is happening is that when I try to instal Component Finder the installer installs the whole package. this installer is ft1.6.1_component_finder_pack_0.6.0. I am probably not being able to download the correct installer. how can I get it?
                                  • halroachH Offline
                                    halroach
                                    You have the correct RBZ - ft1.6.1_component_finder_pack_0.6.0
                                    Before installing make sure the C:\ProgramData\F3d_FlexTools folder is gone.
                                    After restarting Sketchup and reinstalling you should have a toolbar called FlexTools with 2 icons on it.
                                    It should look like this:
                                    • EdsonE Offline
                                      Edson
                                      ok. problem solved. there were parts FlexTools in more than one location and I had to delete all of them for the installation to work.
                                      thanks.
                                      • halroachH Offline
                                        halroach
                                        thanks.
                                        Ok great. Glad it worked out.
                                        • sallyS Offline
                                          sally
                                          Hello,
                                          I too have installed the rbz file, have the toolbar and component browser window but can't load any components or folders. I'm on a Mac running Mojave 10.14.1. No messages on the ruby console.
                                          Thanks, kind regards, Sally
                                          • EdsonE Offline
                                            Edson
                                            @sally said:
                                            Hello,
                                            Depending on the number of components you have in your computer, it seems to take a long time to load them.
                                            • 1 / 2
