    ComponentFinder
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    39 Posts 9 Posters 86.5k Views 9 Watching
      chrisik
      @halroach said:
      Hi Chrisik,
      Please open the Ruby Console: Window > Ruby Console
      Are you getting any messages there when you try to open a folder?
      Yoni
      No, i don't get any messages.
      • halroachH Offline
        halroach
        Please email me at yoni@flextools.cc so we can troubleshoot this issue further.
        FlexTools - Super Quick Windows, Doors, Slats...
          jkoll66
          Hello, Component Finder is a great extension. In a future release could you please allow a way to see the file path somewhere? I have 2 folders on different servers containing the same components. One is a personal folder for my components and the other is a user folder. I've on occasion had the wrong folder open in the Component Finder window. Thanks.
          • halroachH Offline
            halroach
            Hi Jkoll, Thanks!
            When we first started working on ComponentFinder we thought of showing the full path, but we found that it added a lot of unnecessary clutter to the screen, and in most cases it seemed like it's not needed.
            We may add the possibility of viewing the full path in future versions...
            If possible, you could try renaming the folders to avoid confusion. If you can't rename, for the time being, you can click on the little hard disk button every now and then which would open the source folder. It would serve as a double-check to make sure you're in the correct place.
              jkoll66
              @halroach said:
              Hi Jkoll, Thanks!
              The problem is that the contents of my personal folder are Robocopied nightly into the user folder. I can rename the parent folder, but there are child folders that can't be renamed. Maybe you could incorporate a tool tip that flies out from the folder name when you hover over it? Thanks.
              • EdsonE Offline
                Edson
                I installed Component Finder but, since I once had FlexTools installed, it was installed as part of its long toolbar. It did not ask for my license number either.
                My question is: what files do I have to delete to get rid of the FT toolbar? Since I do not use the other tools I would like to have the short toolbar that shows only Component Finder.
                Thanks.
                http://www.mahfuz.arq.br
                • halroachH Offline
                  halroach
                  Thanks.
                  Hi Edson,
                  To completely remove the rest of the FlexTools toolbar:
                  1. Close Sketchup
                  2. If you have no need for FlexTools at all - Delete the following folder: C:\ProgramData\F3d_FlexTools
                  3. Open Sketchup and reinstall ComponentFinder.
                  4. Open the FlexTools manager (gear icon)
                  5. (re)Activate ComponentFinder with your license key.
                  • EdsonE Offline
                    Edson
                    thanks. this is what I had done before. and it worked.
                    what is happening is that when I try to instal Component Finder the installer installs the whole package. this installer is ft1.6.1_component_finder_pack_0.6.0. I am probably not being able to download the correct installer. how can I get it?
                    • halroachH Offline
                      halroach
                      You have the correct RBZ - ft1.6.1_component_finder_pack_0.6.0
                      Before installing make sure the C:\ProgramData\F3d_FlexTools folder is gone.
                      After restarting Sketchup and reinstalling you should have a toolbar called FlexTools with 2 icons on it.
                      It should look like this:
                      • EdsonE Offline
                        Edson
                        ok. problem solved. there were parts FlexTools in more than one location and I had to delete all of them for the installation to work.
                        thanks.
                        • halroachH Offline
                          halroach
                          thanks.
                          Ok great. Glad it worked out.
                          • sallyS Offline
                            sally
                            Hello,
                            I too have installed the rbz file, have the toolbar and component browser window but can't load any components or folders. I'm on a Mac running Mojave 10.14.1. No messages on the ruby console.
                            Thanks, kind regards, Sally
                            • EdsonE Offline
                              Edson
                              @sally said:
                              Hello,
                              Depending on the number of components you have in your computer, it seems to take a long time to load them.
                              • halroachH Offline
                                halroach
                                @sally said:
                                Hello,
                                Hi Sally,
                                1. Was ComponentFinder(CF) working at any point in time, or it wouldn't work when you first opened it?
                                2. Is the CF screen completely gray, or do you see the interface normally?
                                3. Please check if purging the model (Window > Model Info > Statistics > 'Purge Unused') helps in any way.
                                • sallyS Offline
                                  sally
                                  Hello Yoni (?)
                                  1 it has never worked
                                  2 I see the interface normally
                                  3 purging made no difference
                                  When I click on add folder, I can navigate to the folder I want, but all the SKP files within the folder stay greyed out. And nothing loads. I think I will uninstall and re-install the rbz file.
                                  Thanks, Sally
                                  • halroachH Offline
                                    halroach
                                    @sally said:
                                    Hello Yoni (?)
                                    Thanks, Sally
                                    What versions of Sketchup is it on?
                                    Can you please post a screenshot?
                                    Yes, this is Yoni
                                    • sallyS Offline
                                      sally
                                      Hi Yoni,
                                      when I looked at the CF screen and clicked on all the icons, (I think it was the eye one) I saw a message saying please re-start SU to rebuild the toolbar. So I restarted and voila, there they all were. I had 6 lots of the same folder, presumably they had loaded each time I had tried but just didn't show. Su version 18.0.16976 by the way.
                                      Happy bunny now, looks like a great tool. Many thanks, best, Sally
                                      • halroachH Offline
                                        halroach
                                        @sally said:
                                        Hi Yoni,
                                        Not sure what caused the folders not to show, but great to hear it's working fine now 😄
                                        • halroachH Offline
                                          halroach
                                          Glad to announce ComponentFinder was updated to version 0.8.0 😄
                                          The highlights:
                                          • Folder scanning depth is now increased from 5 levels deep to infinity! (and beyond...)
                                          • The maximum number of components in an open folder tab is now up to 6000!
                                          • When opening a new folder tab, the scanning will be going on in the background so you can continue working while it's scanning. Components will be added as they are discovered.
                                          • You can now cancel the scan anytime.
                                          • Faster loading of open folder tabs during CF startup.
                                          • An additional larger zoom level was added.
                                          • You can click on the folder name and it then shows the full path instead.
                                          • When hovering over components, a tooltip appears with the full path.
                                          • The annoying bug where components' thumbnails would suddenly break? Squashed! 👊
                                          To see the full list of release notes => https://flextools.cc/release-notes/
                                          How to update => https://flextools.cc/learn/updates/
                                          • halroachH Offline
                                            halroach
                                            @jkoll66 said:
                                            Hello, Component Finder is a great extension. In a future release could you please allow a way to see the file path somewhere?...
                                            Done! 😎
                                            Check the 2nd and 3rd points before last in the previous post.
