    16' X 10' Apartment
    12 Posts 5 Posters 6.4k Views 5 Watching
      Testing the water as to how low can I go. Two floors each 16' X 10' with yacht steps between.
      Ground floor.
        What is that weird bulging reflection?
          It is a treeline outside the building. For some reason the glass has refracted the hdri backplate, it does this from some angles. I will be trying other glass types.
          • Bryan KB
            Looks good!
              Ta mate, the reflection in the window is proving a pita to deal with.
              I have just checked the glass finish and I used the wrong glass - common finish. Mea culpa.
              Correct glass finish.
                Upper floor
                Bedroom and bathroom
                • tuna1957T
                  tuna1957
                  Looking good Mike πŸ‘ . One small question though, if we're on the upper floor why does the grass outside look like it's on the same level ?
                    Thanks, the hdri thing, I set the render going and went off to do something else, I should have used a generic sky hdri with a background allowing for height of the scene. Another D'oh moment.
                    • DanielD
                      Daniel
                      Have you looked at the "tiny house" movement?
                      My avatar is an anachronism.
                        Thanks, yes. I am trying to wrap my head around the shared space designs. I have used pull out sections before but not been entirely happy with the result.
                        • Bryan KB
                          Looking really good!
                            Thanks Bryan.
