    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 760.2k Views 163 Watching
      When the simulation is running your cursor should be White and the box select has a slight yellow fill...
      Selecting Pins in Clothworks for SketchUp
      • V Offline
        Vitalina Newcomers
        Yes, I understand that during simulation the cursor should turn white and a yellow selection box should appear.
        In my case the cursor does turn white, but the selection still does not work:
        • no yellow selection box appears
        • pins cannot be selected
        • no gizmo appears
        So the issue is not the cursor, but that selection is not functioning during simulation.
          Share the file that fails. Also your version SketchUp and the OS you are using.
          For me its works on SketchUp 2023 to 2026 on Windows
          • V Offline
            Vitalina Newcomers
            Thank you for your response. The issue is resolved.
            The problem was not the license itself. SketchUcationTools was either missing or not working correctly, so ClothWorks could not detect it and did not open the license window.
            I reinstalled SketchUcationTools and now everything works fine.
            • I Offline
              inuk228
              ์Šค์ผ€์น˜์—… 2026 (๋ฒ„์ „ 26.2.243.64๋น„ํŠธ) ์‚ฌ์šฉ์ž ์ž…๋‹ˆ๋‹ค. ๊ทธ๋ž˜ํ”ฝ์นด๋“œ nvidia geforce rtx 2070 super ์ธ๋ฐ
              TIGT 1 Reply Last reply Reply Quote 0
                TIG Moderator @inuk228
                @inuk228
                And your question is ?
                  Korean language detected by google.
                  I am a SketchUp 2026 (version 26.2.243.64-bit) user. My graphics card is an NVIDIA GeForce RTX 2070 Super.
                  ํฌ๋Ÿผ ์‚ฌ์šฉ์ž๋“ค์—๊ฒŒ ์งˆ๋ฌธ์ด ์žˆ์œผ์‹ ๊ฐ€์š”?
                  poleom sayongjadeul-ege jilmun-i iss-eusingayo?
                  What is your question for the forum?
                  • 32
                  • 33
                  • 34
                  • 35
                  • 36
                  • 36 / 36
