    Huntsville Aquatics Center
    17 Posts 11 Posters 3.0k Views 11 Watching
    • boofredlayB Offline
      boofredlay
      Once again I have been blessed to work on another high profile building in the Huntsville area. Here are some model design shots matching photos of the actual project.
      All native SketchUp with some Form Fonts models added in, mostly the people.
      More info on the project here:
      http://www.al.com/expo/ERRY-2018/02/476f41a9f7/index.html
      • cheddaC Offline
        chedda
        Super detail & modelling !
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
          Nailed that, brilliant.
            boofredlay
            Thanks guys.
            • tuna1957T Offline
              tuna1957
              Fantastic modeling πŸ‘
              • tademaT Offline
                tadema
                Great project and modeling πŸ‘ . It's great to see a large project using SU as the main modeling tool rather than just a placeholder for imported models. Top draw stuff.
                John
                  boofredlay
                  Thanks Charles and John.
                  I have been able to do this with a few projects here and we are in the middle of another large one as well.
                  • andybotA Offline
                    andybot
                    Great job on the model! Quick question about the photos. Did you get photos that matched your previous model views, or did you go back and take views to match the photos of the project? I'm guessing the latter, but it would be cool if the SU model informed the architectural photography.
                    • ntxdaveN Offline
                      ntxdave
                      Very good.........Wish I could do something like that. πŸ‘
                      Press F1...thank me later
                        boofredlay
                        Thanks Dave.
                        Thanks Andy. The latter yes. There are some extreme FOV on the photos which are somewhat hard to match.
                        I did the same with this project too.
                        http://sketchucation.com/forums/viewtopic.php?t=67875
                          Lot of work, and so well executed πŸ‘ πŸ‘
                          Curious, why did they engage you to model what was (I assume) was alredy built?
                            boofredlay
                            Thank you.
                            You got that backwards. I work for the architects who designed and managed the project. The model images you see were done before construction began.
                            • david_hD Offline
                              david_h
                              Nicely Done, Eric. Kudos, Congrats and Felicitations all around!
                              • marked001M Offline
                                marked001
                                They really built that exactly as designed, huh? Great job Eric.
                                http://www.revision21vis.com
                                instagram: revi21on
                                • Bryan KB Offline
                                  Excellent work!
                                    Thank you.
                                    That makes sense, must have been a long time between the SU and seeing it come to fruition.
                                      boofredlay
                                      Yep. Started this about 3 years ago. Now we did tweak the acoustical panel layout and colors during construction, updating the SU model to show the owners but the rest of it was done pre construction.
                                      Thanks again all.
