    Huntsville Aquatics Center
    17 Posts 11 Posters 2.9k Views 11 Watching
      Nailed that, brilliant.
      • boofredlayB Offline
        boofredlay
        Thanks guys.
        • tuna1957T Offline
          tuna1957
          Fantastic modeling πŸ‘
          • tademaT Offline
            tadema
            Great project and modeling πŸ‘ . It's great to see a large project using SU as the main modeling tool rather than just a placeholder for imported models. Top draw stuff.
            John
              boofredlay
              Thanks Charles and John.
              I have been able to do this with a few projects here and we are in the middle of another large one as well.
              • andybotA Offline
                andybot
                Great job on the model! Quick question about the photos. Did you get photos that matched your previous model views, or did you go back and take views to match the photos of the project? I'm guessing the latter, but it would be cool if the SU model informed the architectural photography.
                • ntxdaveN Offline
                  ntxdave
                  Very good.........Wish I could do something like that. πŸ‘
                  Press F1...thank me later
                    boofredlay
                    Thanks Dave.
                    Thanks Andy. The latter yes. There are some extreme FOV on the photos which are somewhat hard to match.
                    I did the same with this project too.
                    http://sketchucation.com/forums/viewtopic.php?t=67875
                      Lot of work, and so well executed πŸ‘ πŸ‘
                      Curious, why did they engage you to model what was (I assume) was alredy built?
                        boofredlay
                        Thank you.
                        You got that backwards. I work for the architects who designed and managed the project. The model images you see were done before construction began.
                        • david_hD Offline
                          david_h
                          Nicely Done, Eric. Kudos, Congrats and Felicitations all around!
                          • marked001M Offline
                            marked001
                            They really built that exactly as designed, huh? Great job Eric.
                            http://www.revision21vis.com
                            instagram: revi21on
                            • Bryan KB Offline
                              Excellent work!
                                Thank you.
                                That makes sense, must have been a long time between the SU and seeing it come to fruition.
                                  boofredlay
                                  Yep. Started this about 3 years ago. Now we did tweak the acoustical panel layout and colors during construction, updating the SU model to show the owners but the rest of it was done pre construction.
                                  Thanks again all.
