    Huntsville Aquatics Center
    17 Posts 11 Posters 2.9k Views 11 Watching
    • tademaT Offline
      tadema
      Great project and modeling πŸ‘ . It's great to see a large project using SU as the main modeling tool rather than just a placeholder for imported models. Top draw stuff.
      John
      • boofredlayB Offline
        boofredlay
        Thanks Charles and John.
        I have been able to do this with a few projects here and we are in the middle of another large one as well.
        • andybotA Offline
          andybot
          Great job on the model! Quick question about the photos. Did you get photos that matched your previous model views, or did you go back and take views to match the photos of the project? I'm guessing the latter, but it would be cool if the SU model informed the architectural photography.
          • ntxdaveN Offline
            ntxdave
            Very good.........Wish I could do something like that. πŸ‘
            Press F1...thank me later
              boofredlay
              Thanks Dave.
              Thanks Andy. The latter yes. There are some extreme FOV on the photos which are somewhat hard to match.
              I did the same with this project too.
              http://sketchucation.com/forums/viewtopic.php?t=67875
                Lot of work, and so well executed πŸ‘ πŸ‘
                Curious, why did they engage you to model what was (I assume) was alredy built?
                  boofredlay
                  Thank you.
                  You got that backwards. I work for the architects who designed and managed the project. The model images you see were done before construction began.
                  • david_hD Offline
                    david_h
                    Nicely Done, Eric. Kudos, Congrats and Felicitations all around!
                    • marked001M Offline
                      marked001
                      They really built that exactly as designed, huh? Great job Eric.
                      http://www.revision21vis.com
                      instagram: revi21on
                      • Bryan KB Offline
                        Excellent work!
                          Thank you.
                          That makes sense, must have been a long time between the SU and seeing it come to fruition.
                            boofredlay
                            Yep. Started this about 3 years ago. Now we did tweak the acoustical panel layout and colors during construction, updating the SU model to show the owners but the rest of it was done pre construction.
                            Thanks again all.
