    Selection of objects not correct
    6 Posts 3 Posters 7.6k Views 3 Watching
    • luckyvacL Offline
      luckyvac
      Hello, I changed my computer to solve the problem ...
      Qosmio (After a crash on W10, W7 re-installed) > acer 7530G.
      thank you
      Object selection fault.
        Disable MSPhysics and test it? DO you get the same result?
          Did you install SketchUp correctly by right clicking on the installer and selecting Run as administrator? Or did you just double click on the installer?
          • luckyvacL Offline
            luckyvac
            yes, the same ...but i have make the simulation with 1.0.2 and i have reinstal 1.0.3 .... I think, I check!
              No need to
              start again
              Close SketchUp.
              Find the installer exe file [probably in your Downloads folder?]
              Re-download it if necessary...
              Select its icon.
              Right-click > Context-menu...
              "Run as administrator"
              When prompted choose "Repair".
              When the installation is done try SketchUp again...
              Any better?
              Installing apps in any other way - even if you have admin powers - can lead to all kinds of unpredictable and weird issues...
              • luckyvacL Offline
                luckyvac
                indeed, I did not do it as an administrator. I must start again...
                I do this... but it the same thing ! 😕
