    SketchUp 2018
    173 Posts 63 Posters 47.8k Views 63 Watching
    • ntxdaveN Offline
      ntxdave
      @juju said:
      You could also click on the renew option, enter your serial and a new one for SU2018 will be generated.
      OK - I will show my stupidity - what renew option?
      Press F1...thank me later
      • jujuJ Offline
        juju
        Sorry, I should have been clearer, on the SketchUp website.
        https://www.sketchup.com/license/renew
        Insert your licence, the system will check their database and report on your maintenance status together with a new serial for SUpro2018 if maintenance is current (which it should be from your feedback on when you bought / renewed / upgraded earlier in the year).
          david.
          My 3DConnexion SpaceNavigator doesn't work with 2018. Seems like this happened with 2017, too. I currently can't connect to 3DConnexion.com to check for updated drivers.
          • ntxdaveN Offline
            ntxdave
            Thanks juju........
            Jos so others know, getting the new serial number is not enough (which is all that shows on the web site when you renew). Click on the Send Email link so you will also get the new authorization key.
            • neetsN Offline
              neets
              Hi Dave! πŸ˜„
              Gotta admit, this is freaking me out! No new versions of SketchUp Make??!!
              Say it can't be true!
              I opted for a 2017 Macbook Pro by the way! For anyone reading this, I'm still a Windows gal but I had to invest in a Mac for my business!
              Anita
              Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
                david.
                @charlie__v said:
                David,
                I updated my 3DXware to latest and it did not make my SpaceNaivagtor kick on in SU 2018. (& yes this happened w/SU 2017 as well....a later update from 3DX ware did support 2017)
                So: I copied over the Folder: 3DxSketchUp & 3DxSketchUp.rb from my 2017 SU Plugins folder.
                File path for 2017: C:\ProgramData\SketchUp\SketchUp 2017\SketchUp\Plugins
                **SU 2018 did not have a Plugin folder in the following location so you will have to create one.
                File path for 2018: C:\ProgramData\SketchUp\SketchUp 2017\SketchUp\Plugins
                C
                Charlie,
                That worked for me. Thanks!
                • davidmreinboldD Offline
                  davidmreinbold
                  @panixia said:
                  @dave r said:
                  @function said:
                  Sketchup Make gone... hard to believe
                  @panixia said:
                  Moreover is clear enough that they are developing the software in a direction which only makes sense for architects (maybe).
                  Well actually "maybe not" is the answer for me as an architect. I have been using the software since 'Sketchup 7' for architectural work and these days I am using both Sketchup and Layout to equal parts for modelling and design documentation.
                  Here are my five pennies worth from an architectural workflow perspective...
                  SECTION FILLS
                  This has been overdue since for an entire decade, and is now (thanks to the Skalp team)too little too late and because of this for me the biggest disappointment of this version.
                  ADVANCED ATTRIBUTES
                  I could not care less about this feature. I know BIM is all the hype but in reality I don't see myself using this for reporting such as window schedules on small domestic projects. Window schedules require a lot more individual information which can not easily be pulled from a model i.e. solar direction, action type, glazing options etc. To set up a template for all the options, check and maintain the data pulls trough in a comprehensive way, and then quiet likely still having to tweak and add more specific data would take significantly more time then it could ever safe thereafter.
                  LAYOUT IMPROVEMENTS
                  The ability to draw to scale in Layout may prove to useful(INSTRUCTION VIDEO PLEASE). However Layout still needs a lot more pressing improvements in particular the handling of layer visibility setting when adding new layers which is currently counter productive and very time consuming to put it nicely. Also as JuJU suggested synchronization of layers directly with Sketchup would be a no-brainer and is long overdue.
                  DWG TO LAYOUT
                  Very nice! But does I am not sure how often I will really use it as I try to stay away from Autocad where I can, and importing dwg files i assume means I have to prepare and fine tune the in Autocad first...(INSTRUCTION VIDEO PLEASE)
                  All in all I am quiet unimpressed by the new features and for the first time I am considering of skipping a version...
                    Charlie__V
                    @david. said:
                    @charlie__v said:
                    David,
                    File path for 2018: C:\ProgramData\SketchUp\SketchUp 2018\SketchUp\Plugins
                    C
                    Charlie,
                    Oh good......because I just now noticed small typo on the file path to 2018......fixed now via forum edit. 😎
                      Charlie__V
                      David,
                      C
                      • masterpaulM Offline
                        masterpaul
                        They are trying to force people to eventually buy the pro version. Sketchup Make will eventually become obsolete and inefficient compared to the newer versions. Eventually, newer plugins will become incompatible with the old SketchUp make.
                        Let's not kid ourselfs. Sketchup free is NOT a replacement for make (at least in its current state). They completely misunderstood what made SketchUp so attractive in the first place; it was its ease of use and how powerful it was thanks to its plugins. Without these extensions, sketchup would have been forgotten in obscurity and it would have never achieved the acceptance it has today. Only simple models would have been possible and it would have been too inefficient for anything more complex. These extensions were easy to use and fit into SketchUp's philosophy well.
                        Sketchup free is a purely business move. It has been completely gimped in order to force people into pro subscriptions. They took away features under the excuse of making it easier and more accessible to use. While truthfully they made complex models even harder to create. Even an advert supported Sketchup make 2018 (advert on startup) would have been a better idea then the online free version.
                        The current trajectory will most likely lead to a reduction of hobby users which would eventually reduce the number of extensions in development. Which will lead to a decline in pro users. Even kids will move on from FREE as they eventually will want to create more complex creations (when I was 14, it was only a week before I downloaded my first plugin).
                        And even if someday they add extensions to SketchUp Free, it's online only.
                        • pbacotP Offline
                          As a business, I suppose they don't have any other reason to make moves other than business moves. I think the free version was good for business, but I suppose they've done more homework than simply "I think...."
                            deadtaco
                            @chrisjk said:
                            SU 2018 appears to be available in Oz.
                            (www.sketchupaustralia.com.au)
                            Dunno if this is spoof or real...
                            Is that really all that is new in 2018? Just new types of sections? Seriously? There's gotta be something I'm missing here. If that's the only change, why bother upgrading? There were so many things requested in the 2018 wish list forum post on the Sketchup forums. Did they even look at it?
                            • JQLJ Offline
                              JQL
                              I'm lead to believe they couldn't as Make was standing in the way.
                              LOL
                              Now seriously. Sketchup 8 is still free to use commercially. Make 2017 will be free to use for several years for hobbyists (though it's used by pros too, and that's the reality). Sketchup Free will keep being around and developed. Eventually it will get extensions too.
                              Let the focus be on Pro.
                              I'm an architect by the way. Layout is a main part of what I do. It's getting better by the year.
                              I also see better plugins every year and most of them solve most things being said here. These happen, I believe, due to a lot of work on the API side.
                              www.casca.pt
                              Visit us on facebook!
                                masterpaul
                                There been quite a few cases were businesses got it completely wrong with dire consequences.
                                  masterpaul
                                  LOL
                                  Sketchup free will take more resources away from the offline PRO. It is a completely different beast, most likely runs on a different code (html5). Not to mention that if they add extensions to Free, they will most likely be incompatible with the offline PRO. It would split developers between two bases.
                                  Make was just pro with layout, style builder and a few features locked behind a paywall; that barely took any resources away.
                                  • JQLJ Offline
                                    JQL
                                    I agree with you Master... (bowing head) The future of Make though, is limited in growth. The future of a web based Sketchup, we don't know.
                                    In the past Make and Pro were riding side by side. Consider two branches now. Offline and Online.
                                    Where they will meet again in the future we don't know but it might have some potential.
                                    The thing is that Pro was never distant enough from free. Now it is.
                                    Unfortunatelly this distance wasn't acomplished through breaking ground with new and good for all features, but with cutting down weight.
                                    I too long for UV mapping. For real management of sections. For a streamlined relationship between Sketchup and Layout. For a Layout that truly allows us to draw and tag the model as Pros do. For huge bigger models. Seamless import of any formats. Maneageable billions of polys...
                                    Eventually what I really need is way better plugins to get more pro features that we lack in Sketchup.
                                    www.casca.pt
                                    • wiskillW Offline
                                      wiskill
                                      This year's version was so lackluster they didn't even bother make a what's new video about it.
                                      • jujuJ Offline
                                        juju
                                        I don't know hey, I watched no less than two clips on Youtube last night, by SketchUp themselves (there are others), about new features.
                                        Please get your facts straight.
                                        • jiminy-billy-bobJ Offline
                                          jiminy-billy-bob
                                          No, the core code is the same, only the UI differs. Any improvement made to the core will benefit both platforms.
                                          • PixeroP Offline
                                            Pixero
                                            If the core code is the same, adding support for extensions to the web version would be possible, right?
                                            Or does it already have support for extensions built in but not yet exposed?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 7 / 9
