    Black line Horizon
    renderpluginsextensions
    16 Posts 4 Posters 3.7k Views 4 Watching
      Dprince
      Het guys im doing render ocean type of thing and im using dome light and an hdri but the horizon has a black line that im dont know how to get rid of it anyone can assist? need a fast response im working with a deadline. Thanks
      • filibisF Offline
        filibis
        Hi Dprince,
        Change the 'Shape' parameter into 'Sphere' instead of 'Hemisphere', so that bottom half of the HDRI (below horizon) will render too. Refer to this manual.
          Dprince
          Its already set to sphere , however it still renders that way. Im using vray 2.0
            Dont know if this helps but i had the same problem once. IT DROVE ME CRAZY. After some time I found that it was a stray section plane that the render engine did not like. Worth a try.
            Could you upload the model?
            A work around would be a static background. That would work for sure, but you would need to modify your Sun direction.
              Dprince
              I'll try that. I saw something about vray place i did that but it seems as if vray plane doesnt accept textures
                Then do it another way. Build a vertical plane where the background would be in sketchup. Put the image on that plane. Then render that, have done it many times with good results.
                  Oh, make sure if you do try the background image in SU, make sure the sky image does not have a Sun in it and the camera position is behind you. That will also add more definition to your model.
                  • filibisF Offline
                    filibis
                    Are you sure that it's a spherical (360°) panorama and not a hemispherical (180°) panorama?
                    Can you share the panoramic image you use and SketchUp file?
                      rv1974
                      place Vray plane.
                        Dprince
                        @rv1974 said:
                        place Vray plane.
                        Vray plane worked to get rid of the blackline. however there's a texture i created in vray for the ocean but when i add it to the vray plane and render it doesn't show
                          rv1974
                          Think mate, think
                          just put Vrayplane below sea level
                            Dprince
                            HDRI - https://www.dropbox.com/s/162fmvmh5tb0mhr/hdri_sky_069.exr?dl=0
                            Sketchup File- https://www.dropbox.com/s/o8knd9nscoyziot/AutoSave_MapsShores2017_1.skp?dl=0
                              Dprince
                              @rv1974 said:
                              Think mate, think
                              below sea level? not sure what u mean
                                rv1974
                                Make some huge rectangular (sea) with water material plus some wave displacement and put vray plane under the sea. Remember rendering output is only 1st stage, usually some Pshop doodling should be applied.
                                  Dprince
                                  oh ok let me try that and see if that works
                                    rv1974
                                    but in your case its just 2 clicks in photoshop. google vray wire color render pass.
