    FlexSlat FT 1.2 orientation & construction points
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    3 Posts 2 Posters 8.1k Views 2 Watching
    • O Offline
      optimaforever
      I love FlexSlat and I often use it to quickly model railings.
      1. Is it possible to have a quick parameter to make the slats vertical? By default they are horizontal and I always rotate manually the component to create vertical poles.
      2. In order to place the poles precisely when I don't want a frame around it, I wether keep a dummy frame and when correctly placed, I change the frame size to 0x0, wether I use the script "add construction points to the bounding box corners". This is a generic topic but is it possible to have these construction points generated by default? I mean, a bounding box usable by the SU default inferences?
      vertical slats
      • halroachH Offline
        halroach
        1. I think if I do that, it may make the component heavier, and may make the interface more complicated. If it were a separate component?
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH Offline
          halroach
          1. Try the "frame guide" setting. Does that help?
