FlexSlat FT 1.2 orientation & construction points
I love FlexSlat and I often use it to quickly model railings.
Is it possible to have a quick parameter to make the slats vertical? By default they are horizontal and I always rotate manually the component to create vertical poles.
In order to place the poles precisely when I don't want a frame around it, I wether keep a dummy frame and when correctly placed, I change the frame size to 0x0, wether I use the script "add construction points to the bounding box corners". This is a generic topic but is it possible to have these construction points generated by default? I mean, a bounding box usable by the SU default inferences?
- I think if I do that, it may make the component heavier, and may make the interface more complicated. If it were a separate component?
- Try the "frame guide" setting. Does that help?
