    SketchFab models
    16 Posts 5 Posters 4.7k Views 5 Watching
    • Paul RussamP
      Paul Russam
      I finally got around to playing with SketchFab and I must say that I'm impressed, got 4 models done so far with lots more to go. I've done a little testing with embedding them on a web page and it works well.
      https://sketchfab.com/dma-ni/models
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        Nice!
        BTW, we made a SketchUp embedding tool...
        http://edg3d.io/embed.php?e=cT5Bwde2y8aYRkf%26amp;p=0%26amp;fullscreen=1
        It respects Layers, Scenes and if you applied our own textures they inherited normal/specular maps in the viewer.
        It is not available at the moment though. Check out that link and press the camera icon to toggle the scenes
        • Paul RussamP
          Paul Russam
          That's looking cool! The addition of scene/cameras is a big plus
          Paul Russam
            Yeah, it is nifty. especially for client sharing.
            http://edg3d.io/embed.php?e=riq5PDPf2kk7ws9%26amp;p=0%26amp;fullscreen=1
            It even has lights that you add in SketchUp.
              So chic! 😎
              • Bryan KB
                Very cool and a nice collection, Paul!
                • Bryan KB
                  I just tried it and here is the result.
                  Old susbsea wellhead - 3D model by BryanK
                  Old susbsea wellhead - Old susbsea wellhead - 3D model by BryanK
                  Sketchfab (sketchfab.com)
                  • Paul RussamP
                    Paul Russam
                    Got them integrated onto the website: https://www.dma-ni.com/dma_projects/
                    The 1st 3 projects (and a couple more) have SketchFab models associated with them.
                    Paul Russam
                    • Paul RussamP
                      Paul Russam
                      If you click the 3D Settings button you can edit the materials, lighting, environment
                      Try changing the environment (Lighting tab) to something more industrial and then editing the material(s) to make it a bit more Metal.
                      Also try adding SSAO and Vinette from the PostProcessing tab.
                      I must say that I'm quite impressed with what can be done, the model needs to be stripped and exploded into as few a groups/layers as you can manage otherwise SketchFab can take an eternity to process it, components are especially bad.
                      Paul Russam
                      • L
                        Lavanta
                        Thanks for posting your models! Great work! When did you start using SketchFab?
                        • Paul RussamP
                          Paul Russam
                          2 days ago
                          Paul Russam
                          • Bryan KB
                            Where is this located? I do not see this menu anywhere.
                            Thanks.
                            • Paul RussamP
                              Paul Russam
                              Just to the right of the view of your model
                              Paul Russam
                              • Bryan KB
                                Thank you! πŸ‘
                                OK. very cool controls. I'm impressed.
                                The environment background didn't work very well for me, but the the rest of controls have given the models a far better look.
                                3D models by BryanK
                                View 3D models by BryanK
                                • L
                                  Lavanta
                                  @paul russam said:
                                  2 days ago
                                  Wow, you only started using Sketchfab 2 days ago and you're this good already? That's impressive!
                                  • Paul RussamP
                                    Paul Russam
                                    Replying to one's own thread is usually bad form but I must say I really REALLY like SketchFab.
                                    Since I originally posted this I've added a load more models, have a look: https://sketchfab.com/dma-ni/models
                                    Paul Russam
