    What other 3D file extensions can I convert to Skp?
    6 Posts 6 Posters 1.1k Views 6 Watching
    • L
      Hi all, I need to get a 3D file other than SKP into SKP. It will probably originate from solid works. Can anyone suggest what file extension I should request. Is there anything else I should be aware of?
      Thank you
        Depends on the model and it's construction.
        I tend to go for .DAE if I can get it.
          Use Blender, Meshlab...as converter and input inside SU as obj format... πŸ˜„
          (with Thomthom Quad faces tools or Tig Obj Importer if you have SU Make)
          • A
            ashraf
            Check the following extension.
            It enables SketchUp to import solidworks parts and assemblies.
            • sketch3d.deS
              sketch3d.de
              @ashraf said:
              ...to import solidworks parts and assemblies.
              as converted polygon meshes only, no reasonable way back to SWX.
              available formats for a data exchange here.
              • jujuJ
                juju
                Also take a look at "MooTools" standalone software to convert between formats.
