What other 3D file extensions can I convert to Skp?
Hi all, I need to get a 3D file other than SKP into SKP. It will probably originate from solid works. Can anyone suggest what file extension I should request. Is there anything else I should be aware of?
Thank you
Depends on the model and it's construction.
I tend to go for .DAE if I can get it.
Use Blender, Meshlab...as converter and input inside SU as obj format...
(with Thomthom Quad faces tools or Tig Obj Importer if you have SU Make) -
Check the following extension.
It enables SketchUp to import solidworks parts and assemblies.
Also take a look at "MooTools" standalone software to convert between formats.
