    Problem introducing inches or feet
    12 Posts 5 Posters 2.4k Views 5 Watching
    • J
      Jeff89
      Until now, I used SU with metric units.
      However I have to draw something with feet and inches now.
      However, while drawing a line, SU let me introduce the number, but not the feet ( ') or inches ( ") symbol.
      I can only introduce these symbols, AFTER drawing the line.
      Is this normal behaviour?
      • Jean LemireJ
        Jean Lemire
        Hi Jeff, hi folks.
        If you have millimeters set as your default unit, it is normal that you need to enter the ' (ft) or " (inches) symbol after the value and it is normal that you need to enter a value after drawing the line.
        If you prefer, you can change the default unit to feet or inches by using Menu Window --> Model info --> Units.
        Once done, you can type values without using the ' or " depending on your choice of default unit.
        In short, SU interpret any length number as using the default unit and any length number as alternate unit if followed by**'**or " or mm or cm or m.
        Default unit is a file parameter, thus it may change from file to file. If you foresee the use of different units, you may set-up templates with the units you use the most.
        Best regards.
        • J
          Jeff89
          Thanks for helping me Jean.
          I might not have expressed myself too well before. The problem is that while drawing the line I'm unable to introduce the ' or the " into the box at the right below the screen.
          While drawing the line, I can introduce 102 for example. That will draw a line of 8'an 6".
          If I want to introduce 8' 6", directly, during the drawing of the line, I can't, because I'm unable to tick 'or " into thecornerbox.
          I first have to draw the line, press escape and fill in 8' 6" in the corner box afterwards.
          • G
            Garry K
            I just tried it and it works fine with Windows on Sketchup 2014 and 2017 (your information says you are on Windows and Sketchup 2014)
            My model is mm
            I start the line click where the line is to start and move the mouse in the direction that I want the line. Then I type 8' 6" and the line completes as expected.
            • J
              Jeff89
              Garry: I'm on a mac with version 2015 (the profile information must be outdated).
              I start the line click where the line is to start and move the mouse in the direction that I want the line. Then I type 8', but in the corner I see only 8, without the 'sign. There is no way I can introduce the ' or ".
              • TIGT
                Remember that there should be no gap between the feet and inches.
                So it's:
                8'6"
                NOT
                8' 6"
                ๐Ÿ˜•
                BUT just as I type this, you now say you are on a MAC...
                I suspect another issue...
                Ensure that 'smart-quotes' are NOT set, otherwise the MAC can substitute the wrong kind of quotes !
                ๐Ÿ˜ฎ
                http://www.iclarified.com/38772/how-to-disable-curly-quotes-in-mac-os-x-mavericks
                • J
                  Jeff89
                  Thanks, good try!
                  I turned of 'smart-quotes', didn't solve the issue however...
                  • TIGT
                    Are you sure the preferences for keyboard's smart-quotes is switched entirely 'off' ?
                    If you use the Text tool and type 'cat' and "cat" - with the quotes, do they all come out as simple ' and " quotes ?
                    • J
                      Jeff89
                      @TIG
                      Yes, sure. I followed your link and switched them off.
                      I can type 'cat' and "cat" with the text tool. No problem.
                      • J
                        Jeff89
                        I solved the issue.
                        I had the keyboard language set to "U.S. International - PC".
                        Changed it to "U.S.".... and that did the trick!
                        Thanks everybody!
                          @jeff89 said:
                          I solved the issue.
                          Thanks everybody!
                          That would have taken us a long time to guess. Thanks for reporting the fix.
                          • J
                            Jeff89
                            Yeah, I think so too ๐Ÿ˜„ .
                            However TIG put me on the right track somehow.
                            Thank you all for your help and being such a fine community! ๐Ÿ‘
