    SU 2017 Pro: Toolbars will not stay put?
    4 Posts 4 Posters 728 Views 4 Watching
    • B
      blackdogsketch
      Just installed 2017 on Win10.
      Arranged toobars. Upon reopening, they are all stacked over each other on the main screen ...only two or three docked where I last left them. Have done this twice. Running out of patience. Anyone else running into this?
        Not here. Did you install as Admin?
        • TIGT
          To expand on that...
          Sketchup and most modern apps, in newer versions of Windows, need to be installed properly, otherwise unexpected flakiness can appear later on !
          Find its installer exe file's icon [usually in your Downloads folder ?].
          Select it, then right-click > context-menu > "Run as administrator"
          If you have Sketchup already installed, close it, and then run its installer as explained above... and choose 'Repair' when prompted...
          Being logged-in as the Admin [not recommended], or being a user who has admin-powers, and then launching the installer by double-clicking it or choosing the simple 'Run' option, is NOT the same as using "Run as administrator" properly.
          • sketch3d.deS
            sketch3d.de
            did you have installed under another user account than the used one?
            Try if running SU by "r-click > Run as Admin" once helps already.
