    Table Leg
    11 Posts 5 Posters 1.6k Views 5 Watching
      smhbrv
      Hi everyone.
      I try to model table leg.
      It is X shape, but I did not recurve it.
      How can I model it, pls help me ?
      All profile is 4cmx4cm.
      Pls look at attachment.
      Table
      • ely862meE Offline
        ely862me
        Draw the lines, use offset, create a surface, give thickness then adjust and merge together.
        Elisei (sketchupper)
        Come and See EliseiDesign
          smhbrv
          Can you send a small video pls ? πŸ˜„
          I need more detail help pls... ?
            click to play...
              smhbrv
              @rich o brien said:
              click to play...
              [attachment=0:1f36vufe]<!-- ia0 -->angle.gif<!-- ia0 -->[/attachment:1f36vufe]
              Thank you for your answers but I need sketchup drawing file. I dont do this.
              Can you send me a drawing file pls ?
                It sounds like you want to hire someone to draw this table for you. I could do that if you give me some dimensions.
                  smhbrv
                  Thanks.
                  I send my sketchup file. Look at the attachment pls.
                  My table 80cmx130cm.
                  Legs should be 10 cm inside from the table
                  All profiles are 4cmx4cm.
                  4 legs can turn inside 15/20 degrees.
                  Thank you again.
                  MASA 3.skp
                    So are you agreeing to hire me to draw the table?
                      smhbrv
                      no Δ± want to try to help someone ok ?
                      I need it.
                        smhbrv
                        just Δ± want to learn how can I do this ok ?
                        Pls help me.
                        • pbacotP Offline
                          I thought the video was clear. For laying out use the tape tool and the protractor.
