Table Leg
Hi everyone.
I try to model table leg.
It is X shape, but I did not recurve it.How can I model it, pls help me ?
All profile is 4cmx4cm.
Pls look at attachment.
Draw the lines, use offset, create a surface, give thickness then adjust and merge together.
Can you send a small video pls ?
I need more detail help pls... ?
click to play...
@rich o brien said:
click to play...
[attachment=0:1f36vufe]<!-- ia0 -->angle.gif<!-- ia0 -->[/attachment:1f36vufe]
Thank you for your answers but I need sketchup drawing file. I dont do this.
Can you send me a drawing file pls ? -
It sounds like you want to hire someone to draw this table for you. I could do that if you give me some dimensions.
Thanks.
I send my sketchup file. Look at the attachment pls.My table 80cmx130cm.
Legs should be 10 cm inside from the table
All profiles are 4cmx4cm.
4 legs can turn inside 15/20 degrees.Thank you again.
So are you agreeing to hire me to draw the table?
no Δ± want to try to help someone ok ?
I need it. -
just Δ± want to learn how can I do this ok ?
Pls help me. -
I thought the video was clear. For laying out use the tape tool and the protractor.
