    Don't Panic, Fix a minor problem causes panic & major proble
    12 Posts 2 Posters 13.1k Views 2 Watching
      lmtsketch
      I have a model that I have printed parts from, then I made some modifications (not in the problem area) but now when I save the model, Sketchup 17 wants to repair errors and opens some faces that I cannot close after the Sketchup fixes are applied.I have tried closing the faces with lines, ThomThom Cleanup2, and Microsoft 3D builder on the stl. None have worked. I would like to fix it within Sketchup. I would appreciate some advice. Thanks.
      Sketchup File
        The right hand one fixes OK with SolidSolver...
        http://sketchucation.com/pluginstore?pln=TIG_solidsolver
        The left hand one fails - so it has difference that are too subtle to track-down.
        Delete it.
        Because the two parts appear to be mirror images, why not make a copy of the 'good' one, then move it to one side, and mirror it [using Scale > -1], and edit it to make it unique.
        Now you have two solid groups.
          lmtsketch
          Your fix worked the first time through. I then saved each item as a component and then opened the component as a new file in order to have 2 part models. Now SolidSolver does not work on the component(I get the fix error again when trying to save. I also reopened a backup file to try and start over, this time SolidSolver blew up Sketchup and sent an error report. I am going backwards. [I did create the original 2 pieces by copying and mirroring (Flip along green, rotate blue]
            You also seem to have scaled the instance by some large amount !
            Here's a fixed version - using instances - scaled back...
            Foot_Ball_Full_straight_hole_rec-1[fixed].skp
              lmtsketch
              The first image is what I see when I first open the model you attached. The model has open spaces. The 2nd image is the Sketchup crash report when I run Solid Solver on this model.
              Open faces
              Crash Report
                Where did those missing faces come from???
                Why do you need to run SolidSolver ?
                The component is already a solid as reported in Entity Info ???
                PS:
                This is weird - when I get the SKP back it is faulty !
                  Heres a re-fixed SKP
                  Reports solid for me...
                    lmtsketch
                    I get the same result as the first model. The only opened the file and the faces are missing.
                    Second File open
                      Yes, this is very strange.
                      When I get that 2nd SKP back it has holes.
                      I didn't when I uploaded it !
                        I fixed the missing faces and some issues causing non-solidity...
                        This works fine for me...
                        Reopens from my copy without issues - remaining a solid !
                        Foot_Ball_Full_straight_hole_rec-1[fixed2].skp
                          lmtsketch
                          Yes, This time the file opened properly. I saved the parts separately and they are still good solids. I would appreciate any details on how you fixed these parts.
                          THANKS!
                            I drew over some missing faces' edges and they healed up.
                            However, the one on the shallow-dome part cause a double face to form - it was only zillions of an inch apart - but stopping it being a solid.
                            Because the edges were supporting too many faces !
                            I selected one of those faces and deleted it.
                            Then it reported as a solid.
                            I suspect that there is some incredibly tiny variance in these edges which SketchUp thinks can't support a face - or can - and then adds two faces !
                            Doh !
                            These overlaid faces can some times occur - SolidInspector will show them - but can't fix them...
