    Section cuts showing
    10 Posts 6 Posters 1.6k Views 6 Watching
    • EdsonE Offline
      Edson
      I have a number of horizontal section planes set and they work well as such. but when I look at my scenes they are divided by a line positioned where the section cut is. how can I get rid of them? I know it is something to do with styles but cannot remember what.
      thanks for any help.
      http://www.mahfuz.arq.br
        Without having access to the SKP...
        Have you used any plugins ?
        Like SectionCutPlane or Skalp ??
        The section-cuts should be on their own layers and can therefore be switched off in those views...
        You could also consider having the section-planes on their own layer[s] which can be off in those views ?
          Did you inadvertently create a slice via the context menu?
            If you can select any of these 'cut-lines', then Entity Info should give us clues about where they have come from ??
            • EdsonE Offline
              Edson
              In fact, I created the sections using Skalp and there several layers containing those sections.
              For the time being I solved the problem by finding a scene that did not show the lines and assigning the same style to the others.
              • brettsichellodesignB Offline
                brettsichellodesign
                I don't think this is your styles. It looks as if the plane created from skalp is viewable in the scene. Try turning of the layer where the skalp surface is created and update your scene.
                • JQLJ Offline
                  JQL
                  What could have happened that is related with styles is that the active style applied doesn't have active section cuts, though you created this scene from a floorplan view autogenerated by Skalp, but forgot to turn off its plan section layers.
                  www.casca.pt
                  Visit us on facebook!
                  • EdsonE Offline
                    Edson
                    yes! this must be it. thank you all.
                    • jujuJ Offline
                      juju
                      Isn't Skalp supposed to manage that automatically?
                      • JQLJ Offline
                        JQL
                        I think so, but I don't use it. What I'm trying to say is that the perspective scene probably derived directly from a scene where the plan layers were active and that's maybe why they are also active on the new scene.
                        www.casca.pt
