    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • gullfoG Offline
      gullfo
      good idea to leave the deprecated products in place so if someone is drawing an as-is, they can use them to represent it.
      wondering how complex it is to add new/old components - if this is something only you can do, or if you have some key mapping points on components which could be dropped into the plugin component folder and some text updates to reflect the component anchors, default sizes, rotation point relative to x-y, etc etc. as a means of expanding.
      Glenn
      http://www.runnel.com
      • medeekM Offline
        medeek
        I had the same thought when I thought about removing the old hardware, so yes, keeping them in the plugin is probably the right thing to do for now.
        With some components I could make thing user extendable and allow for uploading custom components however with these type of prefabricated shear walls it is a bit more complicated since they are "trimmable" and they need to carefully setup/modeled so that my logic can deal with them in a systematic and predictable fashion.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.8.9 - 06.05.2022
          • Added a "resolution" parameter into the General tab of the Global Settings for adjusting the smoothness of annotation text.
          http://design.medeek.com/resources/wallplugin/images3/wall_su640_800.jpg
          http://design.medeek.com/resources/wallplugin/images3/wall_su639_800.jpg
          By default this parameter is set to 0.5 which may be a bit choppy/pixelated for some. For maximum smoothness set this parameter to zero (as shown above).
          design.medeek.com
          • medeekM Offline
            medeek
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.8.9b - 06.06.2022
              • Fixed a bug with trimmer studs for garage doors.
              !!!! CRITICAL BUG FIX !!!!
              Note that if you are using more than two trimmer studs on your garage doors you will get an error and your garage door will not be drawn. Update to this latest version to fix this bug with the garage door module.
              This bug has existed for some time and I was probably not aware of it or made aware of it until today because most garage doors don't use more than two trimmers/jack studs. However, it is still strange to me how long it was able to slip by unnoticed.
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 30 - Double Brick Walls (9:32 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  I've decided to kick off the holiday in style and offer a new mdkBIM promotion for the rest of the month of July:
                  http://design.medeek.com/ads/JULY4TH22_BANNER_800.jpg
                  Note: There will be no rainchecks on this promotion and there will also be no discounts on subscription licenses or permanent licenses purchased separately.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.9.0 - 07.07.2022
                    • Added the following window types to the window module: Double Hung, Twin Double Hung, Triple Double Hung.
                    http://design.medeek.com/resources/wallplugin/images3/wall_su641_800.jpg
                    Technically these windows are no different (geometrically) than the single hung variants however the callout indicates that they are "double" hung instead of "single" hung. This addition was per customer request.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.9.1 - 07.08.2022
                      • Added additional grille options for windows and doors.
                      http://design.medeek.com/resources/wallplugin/images3/wall_su642_800.jpg
                      The additional grille options are all GRID options. The "FH" appending the window grille options stands for "Farm House". When this option is chosen the grille is only installed in the top window of a single or double hung type window.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.9.2 - 07.24.2022
                        • Added one additional raised header configuration for windows and doors.
                        http://design.medeek.com/resources/wallplugin/images3/wall_su643_800.jpg
                        http://design.medeek.com/resources/wallplugin/images3/wall_su644_800.jpg
                        The "RAISED2" configuration removes the plate directly below the header. This update per customer request.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.9.3 - 07.29.2022
                          • Enabled independent control of exterior and interior stud depths for staggered stud walls (rectangular only).
                          http://design.medeek.com/resources/wallplugin/images4/wall_su645_800.jpg
                          Previously staggered studs were auto-calculated and one could not independently control the stud depth for the exterior and interior studs. This latest update allows for granular control of the stud depths and makes the staggered stud feature more flexible and useful.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            After some further thought to window and door casings (interior trim) I realized it would be useful to enable a system whereby the user could essentially create their own profiles and add them into the plugin (library folder) themselves.
                            I will probably include some pre-added profiles like the 365 and a few other common ones, but this way it will be much more flexible for the user and customizable.
                            https://aws1.discourse-cdn.com/sketchup/original/3X/4/0/4012ef82410fc508df0062d1591dc52dae72a55c.jpeg
                            I will start with the door casings first and then add this feature to the window module after.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at custom casings:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/2/2/22874a82fbeb911bdc48033e05bfefec73819d3b.jpeg
                              https://aws1.discourse-cdn.com/sketchup/original/3X/6/3/6374f37c55c6383eb8a021f9ca1f3966e00df91b.jpeg
                              Notice that when CUSTOM casing is specified for the Casing Style, the edit or draw menu will provide a preview of the profile as shown.
                              Now I need to work on enabling this for arched doors and also updating the global settings with this new option.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.9.4 - 08.05.2022
                                • Enabled CUSTOM door casings for rectangular doors.
                                • Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
                                • Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
                                http://design.medeek.com/resources/wallplugin/images4/wall_su648_800.jpg
                                http://design.medeek.com/resources/wallplugin/images4/wall_su649_800.jpg
                                Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder. Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
                                I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard. It seems there is never a lack of work when it comes to this plugin.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.9.5 - 08.06.2022
                                  • Enabled CUSTOM door casings for arched doors.
                                  • Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
                                  http://design.medeek.com/resources/wallplugin/images4/wall_su650_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images4/wall_su651_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.9.6 - 08.07.2022
                                    • Added STYLE G and CUSTOM G casing options for rectangular doors.
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su653_800.jpg
                                    I had to add in these two styles since they are used in our own home. I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
                                    The profile for the upper molding is found in the "system" sub-folder of the "library" folder. It can be edited and customized by the user. The file name is: CM_HEADER.skp
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      First look at Style G applied to a window:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/a/e/ae75519ca5908b72904a3969fcbd1c67ea1bdeca.jpeg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.9.7 - 08.09.2022
                                        • Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
                                        • Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
                                        • Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
                                        • Added a STYLE G casing option for rectangular windows.
                                        • Fixed a compatibility bug with CUSTOM door casings.
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su655_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.9.8 - 08.13.2022
                                          • Added a "Label Rotation" parameter for all wall types (0 or 180 degrees).
                                          • Added a default "Label Rotation" parameter into the General tab of the Global Settings.
                                          http://design.medeek.com/resources/wallplugin/images4/wall_su658_800.jpg
                                          http://design.medeek.com/resources/wallplugin/images4/wall_su657_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 31 - Custom Window and Door Casings (15:42 min.)
                                            It's crazy to think that about seven years ago I started these plugins (Oct. 2015) and really had no idea where this might go. With the SketchUp API I've managed to turn SketchUp into a program or environment where you can automatically generate architectural geometry that would normally take a program like Revit or Chief Architect. The API along with the full Ruby language essentially makes it possible to customize SketchUp in just about any way possible, which is what makes it so powerful and fun to tinker with.
                                            Thank-you SketchUp and all the people along the way who created this amazing 3D drawing environment and for me a programmer's paradise.
                                            design.medeek.com
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 80
                                            • 81
                                            • 62 / 81
