    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      There entire WSWH Strong-Wall series is now available in the warehouse:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.8.8 - 06.02.2022
        • Added Simpson Strong-Tie "High Strength" wood shearwalls to the SSW module: 24", 18" and 12".
        http://design.medeek.com/resources/wallplugin/images3/wall_su638_800.jpg
        I don't think the older Simpson wood shearwalls are available for purchase anymore from Simpson but I left them in just in case someone has a need for them.
        design.medeek.com
        • gullfoG
          gullfo
          good idea to leave the deprecated products in place so if someone is drawing an as-is, they can use them to represent it.
          wondering how complex it is to add new/old components - if this is something only you can do, or if you have some key mapping points on components which could be dropped into the plugin component folder and some text updates to reflect the component anchors, default sizes, rotation point relative to x-y, etc etc. as a means of expanding.
          Glenn
          http://www.runnel.com
          • medeekM
            medeek
            I had the same thought when I thought about removing the old hardware, so yes, keeping them in the plugin is probably the right thing to do for now.
            With some components I could make thing user extendable and allow for uploading custom components however with these type of prefabricated shear walls it is a bit more complicated since they are "trimmable" and they need to carefully setup/modeled so that my logic can deal with them in a systematic and predictable fashion.
            design.medeek.com
            • medeekM
              medeek
              Version 2.8.9 - 06.05.2022
              • Added a "resolution" parameter into the General tab of the Global Settings for adjusting the smoothness of annotation text.
              http://design.medeek.com/resources/wallplugin/images3/wall_su640_800.jpg
              http://design.medeek.com/resources/wallplugin/images3/wall_su639_800.jpg
              By default this parameter is set to 0.5 which may be a bit choppy/pixelated for some. For maximum smoothness set this parameter to zero (as shown above).
              design.medeek.com
              • medeekM
                medeek
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.8.9b - 06.06.2022
                  • Fixed a bug with trimmer studs for garage doors.
                  !!!! CRITICAL BUG FIX !!!!
                  Note that if you are using more than two trimmer studs on your garage doors you will get an error and your garage door will not be drawn. Update to this latest version to fix this bug with the garage door module.
                  This bug has existed for some time and I was probably not aware of it or made aware of it until today because most garage doors don't use more than two trimmers/jack studs. However, it is still strange to me how long it was able to slip by unnoticed.
                  design.medeek.com
                  • medeekM
                    medeek
                    Tutorial 30 - Double Brick Walls (9:32 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      I've decided to kick off the holiday in style and offer a new mdkBIM promotion for the rest of the month of July:
                      http://design.medeek.com/ads/JULY4TH22_BANNER_800.jpg
                      Note: There will be no rainchecks on this promotion and there will also be no discounts on subscription licenses or permanent licenses purchased separately.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.9.0 - 07.07.2022
                        • Added the following window types to the window module: Double Hung, Twin Double Hung, Triple Double Hung.
                        http://design.medeek.com/resources/wallplugin/images3/wall_su641_800.jpg
                        Technically these windows are no different (geometrically) than the single hung variants however the callout indicates that they are "double" hung instead of "single" hung. This addition was per customer request.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.9.1 - 07.08.2022
                          • Added additional grille options for windows and doors.
                          http://design.medeek.com/resources/wallplugin/images3/wall_su642_800.jpg
                          The additional grille options are all GRID options. The "FH" appending the window grille options stands for "Farm House". When this option is chosen the grille is only installed in the top window of a single or double hung type window.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.9.2 - 07.24.2022
                            • Added one additional raised header configuration for windows and doors.
                            http://design.medeek.com/resources/wallplugin/images3/wall_su643_800.jpg
                            http://design.medeek.com/resources/wallplugin/images3/wall_su644_800.jpg
                            The "RAISED2" configuration removes the plate directly below the header. This update per customer request.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.9.3 - 07.29.2022
                              • Enabled independent control of exterior and interior stud depths for staggered stud walls (rectangular only).
                              http://design.medeek.com/resources/wallplugin/images4/wall_su645_800.jpg
                              Previously staggered studs were auto-calculated and one could not independently control the stud depth for the exterior and interior studs. This latest update allows for granular control of the stud depths and makes the staggered stud feature more flexible and useful.
                              design.medeek.com
                              • medeekM
                                medeek
                                After some further thought to window and door casings (interior trim) I realized it would be useful to enable a system whereby the user could essentially create their own profiles and add them into the plugin (library folder) themselves.
                                I will probably include some pre-added profiles like the 365 and a few other common ones, but this way it will be much more flexible for the user and customizable.
                                https://aws1.discourse-cdn.com/sketchup/original/3X/4/0/4012ef82410fc508df0062d1591dc52dae72a55c.jpeg
                                I will start with the door casings first and then add this feature to the window module after.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  First look at custom casings:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/2/2/22874a82fbeb911bdc48033e05bfefec73819d3b.jpeg
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/3/6374f37c55c6383eb8a021f9ca1f3966e00df91b.jpeg
                                  Notice that when CUSTOM casing is specified for the Casing Style, the edit or draw menu will provide a preview of the profile as shown.
                                  Now I need to work on enabling this for arched doors and also updating the global settings with this new option.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.9.4 - 08.05.2022
                                    • Enabled CUSTOM door casings for rectangular doors.
                                    • Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
                                    • Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su648_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su649_800.jpg
                                    Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder. Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
                                    I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard. It seems there is never a lack of work when it comes to this plugin.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.9.5 - 08.06.2022
                                      • Enabled CUSTOM door casings for arched doors.
                                      • Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su650_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su651_800.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.9.6 - 08.07.2022
                                        • Added STYLE G and CUSTOM G casing options for rectangular doors.
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su653_800.jpg
                                        I had to add in these two styles since they are used in our own home. I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
                                        The profile for the upper molding is found in the "system" sub-folder of the "library" folder. It can be edited and customized by the user. The file name is: CM_HEADER.skp
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          First look at Style G applied to a window:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/a/e/ae75519ca5908b72904a3969fcbd1c67ea1bdeca.jpeg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.9.7 - 08.09.2022
                                            • Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
                                            • Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
                                            • Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
                                            • Added a STYLE G casing option for rectangular windows.
                                            • Fixed a compatibility bug with CUSTOM door casings.
                                            http://design.medeek.com/resources/wallplugin/images4/wall_su655_800.jpg
                                            design.medeek.com
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 80
                                            • 81
                                            • 62 / 81
