    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      I've decided to kick off the holiday in style and offer a new mdkBIM promotion for the rest of the month of July:
      http://design.medeek.com/ads/JULY4TH22_BANNER_800.jpg
      Note: There will be no rainchecks on this promotion and there will also be no discounts on subscription licenses or permanent licenses purchased separately.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.9.0 - 07.07.2022
        • Added the following window types to the window module: Double Hung, Twin Double Hung, Triple Double Hung.
        http://design.medeek.com/resources/wallplugin/images3/wall_su641_800.jpg
        Technically these windows are no different (geometrically) than the single hung variants however the callout indicates that they are "double" hung instead of "single" hung. This addition was per customer request.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.9.1 - 07.08.2022
          • Added additional grille options for windows and doors.
          http://design.medeek.com/resources/wallplugin/images3/wall_su642_800.jpg
          The additional grille options are all GRID options. The "FH" appending the window grille options stands for "Farm House". When this option is chosen the grille is only installed in the top window of a single or double hung type window.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.9.2 - 07.24.2022
            • Added one additional raised header configuration for windows and doors.
            http://design.medeek.com/resources/wallplugin/images3/wall_su643_800.jpg
            http://design.medeek.com/resources/wallplugin/images3/wall_su644_800.jpg
            The "RAISED2" configuration removes the plate directly below the header. This update per customer request.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.9.3 - 07.29.2022
              • Enabled independent control of exterior and interior stud depths for staggered stud walls (rectangular only).
              http://design.medeek.com/resources/wallplugin/images4/wall_su645_800.jpg
              Previously staggered studs were auto-calculated and one could not independently control the stud depth for the exterior and interior studs. This latest update allows for granular control of the stud depths and makes the staggered stud feature more flexible and useful.
              design.medeek.com
              • medeekM Offline
                medeek
                After some further thought to window and door casings (interior trim) I realized it would be useful to enable a system whereby the user could essentially create their own profiles and add them into the plugin (library folder) themselves.
                I will probably include some pre-added profiles like the 365 and a few other common ones, but this way it will be much more flexible for the user and customizable.
                https://aws1.discourse-cdn.com/sketchup/original/3X/4/0/4012ef82410fc508df0062d1591dc52dae72a55c.jpeg
                I will start with the door casings first and then add this feature to the window module after.
                design.medeek.com
                • medeekM Offline
                  medeek
                  First look at custom casings:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/2/2/22874a82fbeb911bdc48033e05bfefec73819d3b.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/3/6374f37c55c6383eb8a021f9ca1f3966e00df91b.jpeg
                  Notice that when CUSTOM casing is specified for the Casing Style, the edit or draw menu will provide a preview of the profile as shown.
                  Now I need to work on enabling this for arched doors and also updating the global settings with this new option.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.9.4 - 08.05.2022
                    • Enabled CUSTOM door casings for rectangular doors.
                    • Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
                    • Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
                    http://design.medeek.com/resources/wallplugin/images4/wall_su648_800.jpg
                    http://design.medeek.com/resources/wallplugin/images4/wall_su649_800.jpg
                    Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder. Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
                    I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard. It seems there is never a lack of work when it comes to this plugin.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.9.5 - 08.06.2022
                      • Enabled CUSTOM door casings for arched doors.
                      • Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
                      http://design.medeek.com/resources/wallplugin/images4/wall_su650_800.jpg
                      http://design.medeek.com/resources/wallplugin/images4/wall_su651_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.9.6 - 08.07.2022
                        • Added STYLE G and CUSTOM G casing options for rectangular doors.
                        http://design.medeek.com/resources/wallplugin/images4/wall_su653_800.jpg
                        I had to add in these two styles since they are used in our own home. I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
                        The profile for the upper molding is found in the "system" sub-folder of the "library" folder. It can be edited and customized by the user. The file name is: CM_HEADER.skp
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at Style G applied to a window:
                          https://aws1.discourse-cdn.com/sketchup/original/3X/a/e/ae75519ca5908b72904a3969fcbd1c67ea1bdeca.jpeg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.9.7 - 08.09.2022
                            • Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
                            • Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
                            • Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
                            • Added a STYLE G casing option for rectangular windows.
                            • Fixed a compatibility bug with CUSTOM door casings.
                            http://design.medeek.com/resources/wallplugin/images4/wall_su655_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.9.8 - 08.13.2022
                              • Added a "Label Rotation" parameter for all wall types (0 or 180 degrees).
                              • Added a default "Label Rotation" parameter into the General tab of the Global Settings.
                              http://design.medeek.com/resources/wallplugin/images4/wall_su658_800.jpg
                              http://design.medeek.com/resources/wallplugin/images4/wall_su657_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 31 - Custom Window and Door Casings (15:42 min.)
                                It's crazy to think that about seven years ago I started these plugins (Oct. 2015) and really had no idea where this might go. With the SketchUp API I've managed to turn SketchUp into a program or environment where you can automatically generate architectural geometry that would normally take a program like Revit or Chief Architect. The API along with the full Ruby language essentially makes it possible to customize SketchUp in just about any way possible, which is what makes it so powerful and fun to tinker with.
                                Thank-you SketchUp and all the people along the way who created this amazing 3D drawing environment and for me a programmer's paradise.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.9.9 - 08.21.2022
                                  • Enabled an option to specify the location of beam pocket king studs for in-wall columns: LEFT, RIGHT, BOTH.
                                  • Fixed a number of minor bugs related to in-wall columns.
                                  http://design.medeek.com/resources/wallplugin/images4/wall_su660_800.jpg
                                  design.medeek.com
                                  • gullfoG Offline
                                    gullfo
                                    one thought - setting o.c. for column space - e.g. columns on 8' o.c. for a 24' wall could accommodate 4 columns (each end + spaced 8'). as an example, my personal DC wall assemblies, i would make 3 separate sections.
                                    Glenn
                                    http://www.runnel.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.0.1 - 09.03.2022
                                      • Added a "Label Location" parameter for windows: AUTO, INT, EXT.
                                      • Added a "Label Location" parameter for doors: AUTO, INT, EXT.
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su662_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su661_800.jpg
                                      You can now manually configure the window and door labels to be on the interior or exterior of the wall on a per opening basis. The feature added per customer request.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.0.2 - 09.05.2022
                                        • Enabled custom materials for wall framing within the global settngs.
                                        • Enabled custom materials within the "Wall Framing Material" parameter for all wall types.
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su663_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su664_800.jpg
                                        With this update you are no longer constrained to set number of material/texture options for the wall framing. You can now use your own custom material for wall framing. The update was also per customer request.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.0.2b - 09.06.2022
                                          • Fixed a bug with wall presets introduced with the addition of the Label Rotation parameter from Version 2.9.8.
                                          !!!! CRITICAL BUG FIX !!!!
                                          This bug affects wall presets within the "Draw" menu only. The issue was already correct in the "Edit" menu. I strongly encourage everyone to upgrade to this version of the plugin if you have Version 1.9.8 or later currently installed.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.0.3 - 09.12.2022
                                            • Reorganized the door draw and edit menus to include an annotations section.
                                            • Added a "door swing angle" parameter for single and double doors.
                                            • Added the door swing angle parameter to the Door tab of the global settings.
                                            http://design.medeek.com/resources/wallplugin/images4/wall_su666_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images4/wall_su667_800.jpg
                                            The preset angles are: 30, 45, 60, 90, 120, 135. The door swing angle for the door symbol can be set on a per door basis and can also be set to a default value within the global settings. This update per customer request.
                                            design.medeek.com
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 79
                                            • 80
                                            • 62 / 80
