    SVG Exporter
    15 Posts 6 Posters 4.7k Views 6 Watching
    • E Offline
      ericschimel
      I've been looking for an SVG exporter for SketchUp. I found the "flight of ideas" one that looks to be really promising, however it's not letting me save an SVG.
      I tried to find the developer to contact them but I haven't been successful. Has anyone had any luck with this plugin, or another one perhaps? I want to be able to export to SVG with colors....
      Sketchup SVG Outline Plugin by simonbeard
      (simonbeard.github.io)
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • sketch3d.deS Offline
        sketch3d.de
        as a work-around you can export to a 2D-PDF and convert to a SVG with the free Inkscape graphics program, dunno if a color gradient will make it threw.
        Alternatively you may want evaluate the commercial SVGmaker for printing from inside SU to a SVG file.
        • E Offline
          ericschimel
          Yeah, I've been doing that, but that's exactly the workflow I want to avoid. I want to export directly from SketchUp. The bummer is that it appears the Flight Of Ideas plugin should work, there's just some odd bug that's preventing it from actually saving the file.
          -Eric
          Custom Models
            This works for me on Windows 10 and SU2017 Pro
            FlightsOfIdeas.rbz
              sketch3d.de
              @rich o brien said:
              This works for me on...
              Windows 7 x64 w/ recent SUP 2017 M2 x64 too, besides groups/components which needed to be exploded.
              • E Offline
                ericschimel
                That one works for me. Interestingly it has one less button on the toolbar. Where'd you get that from @rich?
                -Eric
                Custom Models
                  There's was a fork on GitHub from simon's last commit. It worked on 2016.
                  I made one changed to this one. But it is still somewhat broken. The jscolor picker is failing.
                  • E Offline
                    ericschimel
                    Ah, so that one actually works which is cool. It's not exporting faces though... Has anyone seen a plugin that can do that?
                    -Eric
                    Custom Models
                      sketch3d.de
                      not a plugin and not for free:
                      ScreenShot
                      SVG
                      • E Offline
                        ericschimel
                        Huh... I wonder if that outputs to scale...
                        -Eric
                        Custom Models
                          sketch3d.de
                          @ericschimel said:
                          ...if that outputs to scale...
                          Rectangle 100 x 100 mm
                          Top View / Parallel Projection
                          ISO A4 Landscape / Scale 1:1
                          ScreenShot
                          SVG
                            Marthelm
                            Hello!
                            I have tried both Rich O Brien's download and the simonbeard version, but nothing happens when I press the "SVG" button on the toolbar. I select the polylines I want to export, all curves are exploded. I really just want this to work 😞
                              @marthelm said:
                              Hello!
                              Someone else also reported that it doesn't work with SU2017. I expect the Flights of Ideas exporter needs to be updated to work with Ruby 2.0. You would need to contact the author or find someone willing to make the updates.
                              • alexschreyerA Offline
                                alexschreyer Extension Creator
                                I still think that the DXF and STL export should be baked into SketchUp Make and web (or included as packaged extensions). Those are the most basic exporters (like DAE) and they would support anything from 3DP to CNC and laser cutting (i.e. the maker community). Folks can then convert DXF to SVG (or just use DXF).
                                Author of "Architectural Design with SketchUp":
                                http://sketchupfordesign.com/
                                  sketch3d.de
                                  @alexschreyer said:
                                  I still think that the DXF ... export should be baked into SketchUp Make...
                                  neverever, with the the key difference (= DXF/DWG data exchange) between Make and Pro removed and already lots of users using Make commercially this would probably have a big impact on Pro sales... au contraire, strip down or better discontinue the Make version.
