    Strange Artifacts Appearing
    7 Posts 3 Posters 999 Views 3 Watching
    • T
      Trip12091
      Hello All,
      All day I have been having strange artifacts appearing in GSU 2017 such as this...
      Every other facet, face, line, plain, etc executed perfectly, except this one area.
      I have also been having ghosting of mesh where a mesh will sort of appear, but not really (should be a closed wall but rather the walls fade to invisible and then I can see the inside of the entity (this is not a "viewing from far away issue"). The pieces of the wall (mesh) will lack definition and have no definitive outline. Often, the shading is just wrong too. X-ray viewing is distorted too, but show nothing there to cause it. This is confirmed by all the other viewing methods too.
      I have shut down and rebooted twice.
      Any thoughts?
      Thanks!
      Trip
        Are you modelling to scale? If so scale the object 100x.
        SketchUp doesn't like faces 1mm or below.
          That looks like it could be graphics card related. What is your graphics card?
          As Rich suggested, for small objects its best to work on it at a larger scale.
          ...appearing in GSU 2017...
          What is "GSU 2017"?
            @dave
            GSU is Gimble SketchUp. The face you make when SketchUp does weird things.
              Thanks for the clarification, Rich. πŸ˜›
              • T
                Trip12091
                Thanks for the feed back guys!
                Yes, I have been modeling to scale for use with 3d printers, which, as you know, are not huge. Scaling-up recently resolved another issue. I guess that should become SOP moving forward.
                Thanks again!
                Oh, so, should I not use GSU for "Google SketchUp"? Every industry and ever tool has it's own nomenclature πŸ˜„
                Thanks!
                Trip
                  It hasn't been "Google" SketchUp for nearly 5 years.
