    Issue Inferencing along the Green Axis...
    21 Posts 7 Posters 3.0k Views 7 Watching
    • utilerU Offline
      utiler
      Hey guys, take a look at this screen video I just exported. This has been happening to me for a little while now and it's really giving me the pips!!!!
      Red axis inference works as does the blue but green just can't be found...
      Is anyone seeing this issue as well?
      InferencingAlongGreenAxis.wmv
      Just Curious...
        Aren't the red/green reversed in the southern hemi? Maybe you installed the northern hemi SU?
        • utilerU Offline
          utiler
          Working again now...!!!
          Just Curious...
            To offer an answer i would say your camera position is preventing the axis inference...
            Click to watch....
            I can't get the blue axis in this camera position. I don't think it's a bug more of a drawback of the inference detection at certain angles
            • utilerU Offline
              utiler
              Ah, that was it....
              I had Geo-location set to Ireland. 😮
              Just Curious...
              • utilerU Offline
                utiler
                No not that at all, Rich. Now its the red axis playing up...
                RedAxis.wmv
                Just Curious...
                • pmolsonP Offline
                  pmolson
                  happens to me all the time. I just orbit around to a different view and grab the object from a different point and then it works. Drives me nuts too.
                  • utilerU Offline
                    utiler
                    Glad it's not just me, Paul. Might tell Trimblers about it.
                    Just Curious...
                    • bazB Offline
                      baz
                      Same here.
                      • Wo3DanW Offline
                        Wo3Dan
                        For everything there has to be some "reason".
                        To me it seems that (found by trial and error) for all three axes there is quite a large blind spot on the viewport center where SketchUp refuses to pick up the axes inference unless using the appropriate [Arrow] key.
                        See attached screenshot in which I divided the screen's viewport vertically and horizontally into four equal parts. (with screentext)
                        Then I checked whether SU could find the axis towards the visible vanishing point. If no, I marked that spot on screen with ***** as screentext. Inside the yellow circle SU lacks the axis inference.
                        This does not depend on which axis is looked at, only the location of the vanishing point.
                        • Wo3DanW Offline
                          Wo3Dan
                          Also see attached skp:
                          model about blind spot for SU in finding axis.
                            slbaumgartner
                            In the images @Wo3Dan showed, the intersection of the Green axis vanishing point with the horizon seems to be visible. But if you ponder a moment, you must realize that this point is infinitely far away and can never actually be seen! The ratio of pixel to distance (foreshortening) thus becomes infinite as you move up the view away from the origin! I think this makes it impossible for the inference engine to determine where you are intending the cursor to be in the model, and it gives up.
                            • Wo3DanW Offline
                              Wo3Dan
                              Hi Steve, Have you tried the model I attached?
                              I only made these observations, ...... marking them all with *****. This does however not explain why SketchUp can't find the axis. (and I don't understand your explanation as to why)
                              You are right that the vanishing point can't bee seen due to infinit distance. But looking at the 'blind' area on screen this seems to be quite large compared to the entire viewport.
                              I wonder if the program couldn't be made to narrow down the blind area to something significantly smaller.
                              The model origin's location on screen has no influence.
                                db11
                                Interesting observations regarding the centre screen inferencing 'blind spot'. This may explain why inferencing is, on occasion, so incredibly frustrating — when most of the time it works like magic. Seems the work-around for now is to draw
                                outside of that centre circle.
                                • utilerU Offline
                                  utiler
                                  I opened your file Wo3Dan and tried it out but didn't see any issues...
                                  Just Curious...
                                    slbaumgartner
                                    Yes, Gerrit, I tried your model. As saved, inferencing on the green axis indeed fails. But if I orbit so that the axis isn't so straight back in the view, green axis inferencing works fine. Having the green axis oriented too close to the "into the screen direction" in perspective seems to induce the problem, and I was suggesting that maybe this direction causes the inference engine to struggle trying to infer how far back in the "into the screen direction" the cursor is marking in empty space. I should emphasize that my explanation was only a theory - without access to the SketchUp code I'm just guessing based on symptoms.
                                    • Wo3DanW Offline
                                      Wo3Dan
                                      So did I, to see if my uploaded file was any better, .... fixed something that I wasn't aware of.
                                      But it is still the same, the indicated area inside the yellow "circle" doesn't trigger inference to any of the three axes. Is there no center blind spot at all for you? is this a screen / graphics card / driver depending issue?
                                      • utilerU Offline
                                        utiler
                                        Ok, done it again.
                                        This time it didn't work on the RED or BLUE axis.... Note I was within a component moving other components around. I also tried to orbit around to various locations to trick it a bit but I just couldn't find those two axises...
                                        The only way is to add guidelines which then works.
                                        Interencing issues.wmv
                                        WorksWhenAddingGuidelines.wmv
                                        Just Curious...
                                        • utilerU Offline
                                          utiler
                                          More of the same.... really starting to annoy me now!!
                                          InferencingAgain.wmv
                                          Just Curious...
                                          • utilerU Offline
                                            utiler
                                            And just tried a new model with nothing in it....
                                            Can't find the red axis.
                                            InferencingInACleamModel.wmv
                                            Just Curious...
                                            • 1 / 2
