    Shortcut issue
    11 Posts 3 Posters 2.1k Views 3 Watching
    • J
      Jkoko
      Hi there,
      I switched from windows 7 to windows 10 and upgraded simultaneously form SU15 PRO to SU17PRO and now I'm facing a new issue. I usually use a lot of keyboard shortcuts to activate sketchup functions but this is not working properly anymore. After activating any function using a shortcut it is not working immediately but i've to click at least once somewhere in the modelling area before i can actually start using the function I've activated. Before those switches functions used to be activated immediately. These additional mouse clicks are really annoying to work with. And the strange thing is, if I select a function using a toolbar button it does work immediately.
      Is anybody familiar with this issue? Does anybody know how to fix this?
      Thank you in advance.
      Kind Regards,
      Jan
      • TIGT
        You should have a default set of Shortcuts - like C-ircle, R-ectangle, S-cale and Spacebar for Select etc...
        On a PC you can export your shortcuts in Preferences into a dat file and then import that back into another version [exclude folders from the dat].
        However, this might be indicative of an incorrect installation of SketchUp - which can have various weird results...
        You probably won't need to uninstall v2015.
        You should try to repair it.
        To do this, find the installer's exe file - probably in your 'Downloads' folder ?
        Alternatively download it again...
        Select the exe file's icon, right-click > context-menu > 'Run as administrator'
        When prompted choose to 'Repair' the installation.
        Restart and see if it works better now.
        You should always install all programs in this manner.
        Simply choosing 'Run', or double-clicking on the exe file's will often not install everything correctly - with permission settings etc... Even if you have admin-powers or are logged in as the 'admin' you should also choose 'Run as administrator'...
        • J
          Jkoko
          Hi Tig,
          Thanks for trying to help me fix this issue. I've repaired SU2017 as you suggested, this however did not result in the desired outcome.
          Let me give you an example of the issue i'm facing, just to clarify the issue:
          If I for example select the paint bucket tool and subsequently click on a face, the face immediately changes color as it should do.
          If i use (in my case) the letter B to activate the Paint Bucket Tool, then I have to click TWICE on the face before it changes color. It almost seems like the first click is for activating the SketchUp Window and only after doing so i can use the paint bucket tool as usual.
          And this happens with every single tool I select. I'm wondering whether it is a Windows 10 Issue.
          Do you any other suggestions? This additional clicking slows me down and it's really annoying as well.
          Kind Regards,
          Jan
          • J
            Jkoko
            Hi Tig,
            I just found that there is a short delay after when activating any tool using a shortcut. So If I wait 1 or 2 seconds after using pressing the shortcut the activated tool (via a shortcut) does work immediately. But this still slows me down seriously. The question remains: why the delay?
            I just upgraded my system seriously, so it's more than capable of dealing with SketchUp. That can't be the problem...
            Do you (or does anyone) have any idea why there is a delay (only when using skortcutkeys)??
            Kind Regards,
            Jan
              Is the title bar for the SketchUp window losing focus when you hit a key?
              Place a floating toolbar in the model space. Does it vanish when you hit a key?
              • J
                Jkoko
                Nope, SketchUp doesn't loose focus, the toolbar did not vanish. It is really a delay. If I just wait for a second or two the activated tool functions as it should do. But the delay really shows me down because i use a lot of shortcuts. Any other suggestions?
                  Can you export and zip your preferences file and share it?
                  • TIGT
                    Please confirm that you have installed/repaired SketchUp using 'Run as administrator' option, and that you have updated your Graphics Card drivers, and tried various Preferences > OpenGL settings too.
                    Perhaps uninstalling and reinstalling is needed ?
                    • TIGT
                      When you say you installed SketchUp as admin...
                      That doesn't quite confirm if you did it properly !
                      Simply being the admin [not recommended] or a user with admin-powers, is NOT sufficient.
                      You must find the installer exe file [in Downloads ?], right-click on it > context-menu "Run as administrator"
                      That is the only correct way of installing it...
                      It it's already installed then choose 'Repair'...
                      • J
                        Jkoko
                        Sorry for my late response. My brand new laptop was sent back to the manufacturer for repair. I decided to wait to see whether this would also resolve the delay issue. Unfortunately, I’m still experiencing the delay issue as I did before. It’s a strange phenomena. Once I hit a shortcutkey, the cursor icon changes immediately, Sketchup does respond to mouse movement, but doesn’t respond to mouse clicking for about 2 seconds.
                        I tried several other things as well:
                        • First of all I decided to test whether GTX 1060 is functioning the way it should (the manufacturer claims it does) and whether SU is using the NVidia GTX 1060 card as it should and not the integrated Intel graphic card instaed.
                          I’ve used the Unigine Valley Benchmark to test the 1060 and it scores ok (as far as I can tell). Furhermore I did a FPS count while orbiting a huge SU-model using both (50MB, +1million polygons) the GTX 1060 and the Intel graphics card. The Intel card scored only 1-3 FPS while the GTX scored 30+ FPS. Considering both experiments, I would say the GTX is functioning correctly.
                        • I've also experimented with various OpenGL settings: no improvements
                        • Next I uninstalled all extensions. Once again, no improvements
                        • Reinstalling SketchUp (as administrator) didn’t help either.
                        • Last of all, I compared the performance of SU15 to SU17 on this machine. The performance is exactly the same. Both versions show the same delay.
                        Do you have any other suggestions? Any clue what might be causing the delay?
                        Grtz,
                        Jan
                        • J
                          Jkoko
                          Thnx TIG for trying to help me. Yesterday I installed sketchup the way you suggested, sitting on a couch using the touchpad. After doing so, I opened Sketchup to see whether the issue was solved and it seemed to be functioning the way it should, finally!
                          To be sure, I connected the mouse to the laptop and once again I was experiencing the delay issue with shortcuts. So it wasn't Sketchup nor the hardware which was causing the delay, but it turned out to be the mouse! Since it was functioning fine otherwise, I never even considered the mouse to be the problem. After reinstalling the mouse driver the problem was finally solved. It's so simple if you know where to look.... 😄)
                          So PROBLEM SOLVED! Thnx for helping!
